Question about Home
Armitage shanks s9750
Wont flush
I need a supplier for an Armitage for spears for a toilet and washbasin purchase 33 years ago
Your local plumbing centre should be able to help you if you take a picture of the parts you require.
Jan 30, 2015 | Home
Have old, (but good) 6217 c model. Cannot attach button hole foot, seems too long for the shank that you attach feet to. Only one hole in the shank and the shank on the button hole foot is too long for...
You are trying to attach a long shank foot to a short shank machine. Look for a short shank foot on either Ebay. You may also find it included within a "tin" of accessories at a local thrift shop. If neither of these options work for you check with your local fabric store or sewing machine repair shop for the correct button foot.
May 13, 2011 | Singer 1120 Mechanical Sewing Machine
How do i flush the pipes out? (when i flush the toilet it will not re-fill water) one of the answers was to flush the pipes
If you have a supply shut off to fixture shut it off and disconnect supply line from inlet to toilet . If your supply line to toilet is a flexible line then bend it so that you can direct water to small container. Slowly turn valve on to see what flow rate is at that point. If flow rate is not good then I would shut water off to house and replace valve. If flow rate to toliet is good I would reccomend you replace flush vallve. To do this shut off water supply to toilet. Disconnect supply nut to bottom of flush valve. There will be a retaining nut that holds flush valve in place in toilet tank. Remove flush valve after removing fill tube from flush valve to overflow tube. Replace with toto replacement valve or use Fluidmaster 400A. Instructions on box of 400A are easy to follow and if you have flex connector you won't need supply line washer. I would reccomend that before you install new valve that you put rubber gasket on shank of valve and slid it about halfway up the shaft. Make sure that inside of tank is dry and use a small bead of silicon caulking on top and bottom side of shaft gasket. slid gasket the rest of the way on valve shank,install in tank and put on retaing nut hand tight. Push down on top of valve and using channel lock pliers finish tightening nut securely.You may need to reach into tank and grasp valve body to stop it from turning. There are other things you can do if you have a working supply valve. Shut off valve and remove screws that hold top of valve in place and remove and clean surfaces. You can turn valve on slowly to help flush out any rust or mineral deposits. I hope this is of some help to you. Thanks
Nov 21, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
WHERE CAN I GET SPARE PARTS FOR 57935AA ALTERNA QUADRANT LEVER TAPS CLOSEST TO RUSHDEN NORTAMPYONSHIRE
PTS (Plumbing Trade Supplies) are one of the largest suppliers of armitage shanks brassware. Look them up in the phone directory, im sure there will be a store near you. You should be able to order spares from them.
Oct 06, 2010 | Home
Singer sewing machine 2662 wont' work with Singer darning foot
Are you sure it is the right foot for your model sewing machine?
If the machine has a snap-on presser foot, the adapter the foot snaps onto needs to be removed.
The newer models have a lower/short shank and older models have a higher/longer shank. And then there are the old models with a slant shank.
Chart - http://www.clotilde.com/pages/which_foot.html
May 06, 2010 | Sewing Machines
Does this machine have a low shank --- or high shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop
Bargain Box
Apr 19, 2010 | Janome Memory Craft 9000 Computerized...
My Necchi 681c has snap on feet,can other makes used with it
Yes, probably. You'll need to unscrew the little gizmo that holds the snap on feet, then you can use that same screw and hole in the shank to screw on other types of feet. The most important thing is to know whether you have a low shank, high shank, or slanted shank machine, because feet of one type can't be used on other types (low shank feet can't be used on high shank or slanted shank machines, for example).
Jan 13, 2010 | Necchi Sewing Machines
I have a ixtreme x854 sn 100928580358 i have used the recovery cds before ane they were fine but wont work this time i think they have got scratched and so was wondering about getting another set and how...
You can get another set by searching through eBay or contacting the manufacturer. You can also use a regular operating system disk to get the job done. You can call us at 800-595-3564 if you need further assistance.
Jan 11, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
SUM 5/16 INCH 7/8 INCH
I DONT REALY UNDERSTAND THE QUESTION BUT --- 5/16 + 7/8 = 1 3/16 0F AN INCH OR
AN INCH AND THREE SIXTEENTH OF AN INCH
DOES THAT HELP ?
Nov 17, 2009 | Bosch 85414M 7/8 Inch Diameter 5/16 Inch...
Home Logo
152 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
