Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Husqvarna 140B backback blower won't start! It will run on full choke for about 5 seconds then shut off and i changed the fuel filter, drained fuel lines, put new fuel into it.....wrong mixture? spark
Husqvarna backpack leave blower won't start
boscia
  • 163 Answers
SOURCE: my husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Posted on Nov 30, 2008
SOURCE: Husqvarna LGT2654 with Briggs & Stratton Intek Engine won't start
If the fuel line is dry after the fuel pump its usally the diaphram thats stuffed does it have a fuel tap in place? is it off? also i know with nem mowers just been come over from freight the fuel filter is full of oil for the first start up as the valves need lubrication first startup... take the fuel line off from the carb just have it hanging down for a start, then crank the mower over, you should then have fuel coming out of fuel line by then... see if that helps jay QLD AUS
Posted on Feb 24, 2009
SOURCE: leafblower
carb adjustments weedeater gb1 22v
Posted on May 26, 2009
SOURCE: Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
Posted on May 31, 2009
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
Husqvarna problems
call Husqvarna about a possible recall, ore requst warranty service for your unit.
Aug 08, 2014 | Husqvarna Backpack Leaf Blower 580 Bfs W/...
Handle assembly
Request a handle assembly diagram from Husqvarna.
Dec 08, 2017 | Husqvarna 130bt 130 Bt Gas Powered...
Husqvarna 350 bt won't start
Do you have good compression, good spark and is fuel getting into the cylinder.? More information would help diagnose the problem.
Jun 03, 2012 | Husqvarna BACKPACK BLOWER 350BT
My backpack blower won;t start. I replaced the spark plug and it still won't start. Can you make a suggestion?
Check and make sure the rubber hoses coming out of the fuel tank are not broken and look inside also if not that carb is cloggged up maybe pull the fuel hose off and spray some gumout up into it to open up the jet, spray some gumout in the carb and see if you get a sputter out of it then you know your not getting any fuel.. carb needs cleaning
Oct 03, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 356 backpack blower,when it gets hot it seems like its running out of petrol then cuts out.when it cools it starts ok,but then only runs 15mins and does the same again.
Hello. You may have a partially gummed up carburator. Get a bottle of SEAFOAM at the auto parts store. follow the directions about how much to add and add it to your fuel. Run a couple of tanks of this enhanced fuel through your blower and it should be aok. Regards, Joe
ps - kindly rate my answer. thankyou.
Feb 04, 2010 | Husqvarna Backpack Blower, Model No. 356bt
Husqvarna 155bt Gas Backpack Leaf Blower throttle adjuster does not hold throttle down. just spins.
Do you mean the throttle lock? It is a basic mechanical lock. If it just spins I would assume that a chunk of plastic has broke off or the lever is misplaced. Take the throttle housing apart and identify the problem. New parts are available from your local Husqvarna dealer.
Nov 25, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Oct 21, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
22 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
