Question about Toro Garden
How to drain fuel toro timecutter ss4235 - Toro Garden
2 Suggested Answers
  • 97 Answers
SOURCE: Draining fuel tank in TimeCutter Z5040
Drajn tank through fuel line.
Posted on Mar 25, 2009
Can the toro timecutter ss4235 bagger stay on when using the trailer hitch?
Simple answer herei "No" the trailer hitch gets in the way of the bag holder system sorry I know of no adaptations either
May 21, 2016 | Toro Garden
When I am cutting the grass, when I try to go uphill the machine stalls . I am able to start it up again but a few minutes later the same thing happens.
Check the oil level...some engines have a low oil shutdown float inside the crankcase ..going up hill for an extended period of time allows the oil to flow to the side of the crankcase activating the float and tricking it to think the oil is dangerously low and shut it down...if it does it should have a small wire on the side of the crankcase..try operating on hill for shorter times..and make sure your crankcase is full...good luck..
Aug 01, 2015 | Simplicity 42 Toro Timecutter 20hp Kohler...
Toro wont start
Clean the fins on top of motor and engine.
Sep 07, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Toro ss4235 wont go into gear nor bypass valves wont take it out of gear
try forcing the wheel to move get the ztr rear off the ground and try turning the wheel if dont but pump sqeeled you have a bad check valve or pump is going out i say bad check vale rebuild it
Sep 03, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
Timecutter 42 kholer electrical problem
The battery may not be chargeable and will have to be replaced.
Apr 20, 2014 | Simplicity 42 Toro Timecutter 20hp Kohler...
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
170 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
