Question about VAX Appliances Vacuums
Full manual for vax hard floor. Ultimate steam cleaner s3s-u
How to change heads
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
heatman101
  • 43501 Answers
SOURCE: Using the Shark steam cleaner on floor with unsealed grout
Yeah it will work fine...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
nonontech
  • 4737 Answers
SOURCE: instruction manual for a vax
There is no specific manual available for this model, but you can get the Vax V series manual and technical reference guide.
1. Vax multifunction vacuum cleaner user guide (pet)
2. Vax multifunction vacuum cleaner user guide (family)
3. Vax technical Draw Reference (V11 page No.2)
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
mamaboop
SOURCE: I need an instruction manual for a Vax Rapide
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Posted on Feb 14, 2012
  • 1575 Answers
SOURCE: instruction user guide for a wash vax 6131 cleaner
Hi
Download the manual from the link below.
http://www.vaxireland.ie/downloads/pdf/6131_user_guide.pdf
Hope it helps.Thanks!
Posted on Feb 27, 2012
Did I order my S3S vax floor steamer from you?
no
fixya sit doesn't do orders
Oct 19, 2017 | Vax Vacuums
How do iput water in a vax hard floor advance+steam cleaner s3s+
look for a big knob that you can unscrew. When you locate this knob unscrew fully and add water......then screw tighten and you are ready to turn on appliance.
Dec 06, 2014 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
heatman101
Jul 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Have Shark steam mop...used it but my floors are sticky.. ceramic tile....not all ove...what can I do????? and can I use vinagar in it
Yes, vinegar will work...may not steam right though...
heatman101
Jan 21, 2010 | Euro-Pro Ultra Steam SharkTM II Hard...
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Kirby Ultimate Diamond Edition G Series, upright. Problem: I lost my manual. How do I use my vacuum on hard wood floors? How do I use attachments, where do they attach?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576029
Generic problem for all Vacuums
Posted by jlutsi on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can cal the Kirby factory to request a new owner’s manual and they will describe how to use the vacuum on hardwood floors. There is a felt piece as wide as the brushroll area that will clip on to the bottom of the revolving brush area so that you hard wood floors don’t get scratched. The Kirby head will dial off and the Kirby head will come off and the attachment hose will connect to the front of the Kirby and that is how you use the attachments. Also contact your local Kirby vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Vacuums Logo
118 people viewed this question
Top VAX Appliances Vacuums Experts
richie46
Jim
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
