Question about Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel
Grohe shower handset leak - Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel
4 Suggested Answers
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 8 Answers
SOURCE: Grohe model 27140 leaks
Check for a deteriorated washer inside the connection. Also try wrapping the threads with silicon plumbing tape before reconnecting. If you need to use a tool to disconnect, please tape the tool so it doesn't damage the finish on your hand shower.
Here's a link to the Grohe website and several drawings for your unit. I hope this will help solve your problem. There is also a link for support on that page if these solutions don't work for you.
Posted on Mar 16, 2011
I have grohe 1000 shower and there is a constant water dripping from the head. What could be the problem
The water shut-off valve is leaking, thus not completely shutting off the water supply to the unit. Need to be repaired/replaced.
Mar 14, 2016 | Grohe Aquatower 1000 Shower System 27 016...
TRITON SHOWER WATER LEAKING DOWN WALL AT THE BACK
Sorry to say most parts are plastic and sometimes deform,the cost to repair could be more than a new unit.very easy to swap,bite the bullit
and replace
Jul 01, 2014 | Grohe 25 597 Talia Tub Filler w/Personal...
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
Grohe model 27140 leaks where the hand shower connects with the shower hose
Mar 14, 2011 | Grohe Rainshower Rustic 24" Shower Set -...
The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Jun 24, 2009 | Grohe Movario 59" Metal Shower Hose -...
I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel Logo
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
