We have a Proselect thermostat.It will only blow out cold air and is there a way to change to " manual "
hotuna
  • 288 Answers
SOURCE: heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Posted on Nov 05, 2007
  • 651 Answers
SOURCE: heater blowing cold air
squeeze the hoses to get any air bubbles out and refill coolant as necesary. are you sure you put thermostat in the right way? may be backwards. also may be your sensor.
Posted on Jan 04, 2009
diths_kri
  • 67 Answers
SOURCE: central heating HVAC blows cold air -
stat or low battery in tstat
Posted on Jan 07, 2009
SOURCE: Home Heater Unit Blows Out Cold Air
Throw the **** out
Posted on Jan 23, 2009
theroadis
  • 81 Answers
SOURCE: coolant problem
Sounds like you might have an air pocket in the cooling system. This can develop, usually after a service, where the cooling system has to be opened to replace a water pump, thermostat, or other reason. When refilled, the air displaced by coolant has to go somewhere. In many cases, youll find that air is trapped in the highest place it can go...above the level of the radiator cap or overflow bottle. This can be a portion of the upper rad. hose, a heater hose, or a coolant line running thru various parts of the intake/throttle body area. What I do after topping up the system, is let the engine warm to normal op. temp./ W radiator cap still off. When upper hose becomes hot, you know thermostat is open. Now, if a bleeding device is not present, back off a hose clamp at the highest point in the system. Take a pair of pliers and twist the hose just enough to break the seal. You should see steam or drops escaping from your "breach". Once the steam stops and becomes all coolant, you have likely bled all air from the system. Top up radiator and coolant bottle to proper mark and close the system. (tighten your hose clamp) Check for leaks. Keep an eye on your system for a day or two, to insure no leaks are present.
Road
Caution! As with any task that involves opening the cooling system...Coolant and water can become very hot. Hot water and steam can be very dangerous. If you dont feel qualified to perform this task, let a mechanic do it!
Please Rate me by scrolling down to the colored flags and choose which catagory best fits my response.
Thanks.....
Posted on Feb 04, 2009
How do I clear my setting on my proselect thermostat
Removing the batteries for a few moments may do the trick? If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 13, 2017 | Heating & Cooling
No heat but blows cold air
the control panel is not working you can switch it manual behind the dashboard and beside the gas pedal almost
Nov 24, 2013 | Chrysler Fifth Avenue Cars & Trucks
Bmw x5 heater blows cold
Replace the thermostat.
Oct 21, 2013 | Cars & Trucks
2001 mitsubishi galant heter dont work blows cold replaced thermostat and radaitor still cold
There is probably some kind of damper that opens and closes under the dash that allows the air from the blower to be blow across the heater core under the dash. Sometimes these are controlled electronically or by vacuum tubes. Look underneath the dash and look for small vacuum hoses that might be dangling loose or possible little wire cables that might have come off the sides.
Possibly check Haynes Manuals (www.haynes.com) to learn how to change a Heater Control Valve.
Dec 15, 2011 | 2001 Mitsubishi Galant
My saturn is not blowing cold air , changed thermostat
try getting your aircon regassed if its not blowing cold air, the thermostat dosent have anything to do with the cold air, only the hot air hope that helps
Jan 31, 2010 | 1997 Saturn SL
2000 satin sl1 heater blows cold air, had the
my 2000 saturn sl blows cold air with the heater on. I changed the thermostat,and checked out my heater core.Still blows cold air.
Jan 17, 2010 | 2000 Saturn SL
Friedrich a/c zq10 thermostat won't kick in
likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Jun 18, 2009 | Friedrich ZStar ZQ10A Air Conditioner
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
