Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
Entry combo and lock does not clear to re lock
Enter combo open door when door closes you can pull handel down and door will open with out putting combo in
How do you open a car door if the door is closed and the door handel doesn't work ?
Try getting in from the other side and then opening the trouble door. This sometimes happens when the door wasn't closed properly, or the lock was activated with the handle pulled. It happens on both of my cars, one a Honda and the other an Oldsmobile.
Apr 02, 2015 | Mazda MAZDA6 Cars & Trucks
Back door close lock
check 2 c if the door latch isnt alredy closed if it is pull handel and use screw driver 2 flip it back out
May 12, 2013 | Hyundai Entourage Cars & Trucks
Volvo s40 driver door When locked with key just opens with the handel from outside
Sound like the linkage between the lock cylinder and the door latch has become disconnected.
Feb 05, 2013 | s40 decal. decals doors 2003- mercury;
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
The power door on our 1998 Silhouette van will not close. The door starts to close and at the last second, as it starts to touch the locking mechanism, it retreats as if there is some resistance. The...
Your problem is the door thinks that it is already locked and closed. You need have the sliding door unlocked, have someone pull the handle as if they were going to open the door and then use a tool to "Open" the latch that normally would hold the door closed.
Jul 02, 2011 | 1998 Oldsmobile Silhouette
Reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code ( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the trunk,
type: S(Clear) and the New 4 digit code and the door will open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
Oct 23, 2008 | 1994 Nissan Maxima
Drivers door will not open
Dear Customer,
it happens cause of some gears are locked up which handeled you lock pulled up your side key of you door so ,
you ahve to go to your service center haviong certified mechanics can help you ,
its need to open your door inner mechanism to solve this prob,
THNX
May 18, 2008 | Hyundai Motor 1998 Sonata
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
