Question about Onkyo TX-SR804 7.1 Channels Receiver
Help Hello, I own a Onkyo TX-SR804 7.1 surround receiver. I recently moved it to a different part of my room. I put all the wires and plugs in the same places, even took pictures so I wouldn't do anything different. Now I have a problem. Everything works fine until I increase the volume substantially. When this happens the receiver shuts off. I know this is a protective device to prevent the receiver from blowing. What could be wrong. Thank you, Jim Fliss
    Problem Solver:
  • 20 Answers
Check the rated impedance of your speakers. Use the manufacturer's rating. Don't try to measure it with an ohmmeter. This should be printed on the rear panel. If not, check your manual if you have one. The receiver probably shouldn't be connected to speakers rated any lower than 6 Ohms. If the speakers are 6 or higher, check your wires and connections for any stray strands that could be causing a short. I also have to wonder what "increase the volume substantially" means. Are we talking potential hearing damage? Maybe the receiver is saving you from your self.
Posted on Oct 10, 2007
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
I just bought an Onkyo tx-s804 receiver. and some new rear surrounds. Since I am moving, have not set up anything formally, but have plugged my dvd player into the front video 4 input via an optical...
PCM is what it's receiving from the DVD player. The player has output bitstream settings, too, maybe even speaker configurations and distances. Read its manual.
May 11, 2011 | Onkyo TX-SR804 7.1 Channels Receiver
Wire diagram for surround sound
http://static.fixya.com/Manuals/O/Onkyo/TX_DS595_5_1_61851C3AAA3EA98913A226B1F1FDDAD1.pdf there is the manual for your unit
May 08, 2011 | Onkyo TX-DS595 Receiver
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Onkyo TX-SR804 7.1 Channels Receiver Logo
115 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
