Question about Whirlpool WTW4950XW Washer
Stuck in sensing cycle / and wont spin during last spin cycle
Washing maching has been getting stuck during the sensing cycle
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
SOURCE: spining makes noise and machine vibrates a lot
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
Posted on Sep 01, 2009
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
My washer wont spin
probably the uneven load sensing system must have sensed your drum wobbles too much during spin cycle and cut off spin. its a safety system to avoid damage. Or if your machine has "spin stop" selection, make sure it is turned off.
Mar 19, 2010 | Washing Machines
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Whirlpool WTW4950XW Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
