Question about Sony RCD-W1 2-Disc CD Recorder
Rcd-w1 drive door
Left side drive door does not open. I hear the motor running when I hit the "open" button, but the drive door does not budge. There is currently no cd in the drive.
5 Suggested Answers
  • 14 Answers
SOURCE: RCD-W10 Sony CD player/recorder left tray
Two things generally make this happen. One is electrical and the other physical, First check to see if a light comes on when it is supposed to be working. If not, you'll likely need to get it back to the shop from whence you bought it. You don't say whether this item is new or you've had it some time. The other physical problem is a disc left in the drawer which is not 'sat' down properly, effectively jamming the tray. If this is the case you will see the drawer trying to open. On the front of the CD drawer you will see a very small hole (big enough for an unbent and straightened paperclip) that is used for manually opening the tray. The pin does not have to go in very far and only slight resistance should be felt before the tray drawer opens. If this does not work ........ back to the shop where they open it up and sort the problem. I do not encourage people to open electronic deveices thyemselves as ther are many delicate parts inside that could inadvertantly be damaged. Despite which you would be invallidating any gaurantee you have on the product.
Posted on Mar 15, 2011
dunnbiker
  • 8546 Answers
SOURCE: Why does it say "no
You're trying to use a blank data disc. Use one that says "audio' or 'music". It's in the manual.
Posted on May 03, 2011
SOURCE: how can i use RCD
What you need is a tape deck with 2 rca line outs L&R. Hook them up to the analog ins on the player. rec on deck b. Dont forget to get the right cdr's , i guess you need "music" or "Audio" crd-r's
Posted on Nov 03, 2011
Power window won't go down but you can here the motor running in the door
You can remove the door handles and power window switches and the screws in the door pad and push up on the pad and it will come out of the track and then you can see the motor and replace the part yourself. Hope this helps.
May 05, 2017 | Chevrolet Camaro Cars & Trucks
How do I get my Sony RCD-W1 to record from one CD to another
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
Dec 09, 2012 | Sony RCD-W1 2-Disc CD Recorder
Power window wont roll up on driver's side
If, when you hit the button, you do not hear anything at all, it is most likely the power window motor is burned out. If you hit the button, and can hear the motor running in the door, your window is either off it's track, or the motor is worn out where it connects to the cracking mechanism and is not catching it. Popping off the door panel will give you access and you'll be able to see first hand what it is doing once you hit the button. Less likely reasons are a disconnected switch, wire short at the switch, or condensation on the switch.
Oct 01, 2012 | 2003 Suzuki XL-7
Why does it say "no
May 03, 2011 | Sony RCD-W1 2-Disc CD Recorder
Right side cd will not open. Took off cover and if I push down slightly on the apparatus in front of the ribbon the door will open but only if I push down on that point
There is a small round rubber belt which allows a motor to open the tray. Open the tray, as you say you can, Remove the mains plug. Remove the mounting screws for the deck and you will find the small drive belt underneath. I would recommend buying 2 belts and replacing them both. The diameter is 1 or 2 mm less than the old one (because they stretch)
Dec 19, 2010 | Sony RCD-W1 2-Disc CD Recorder
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
Jul 13, 2009 | Philips DVP5140/37 DVD Player
Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Mar 16, 2009 | 2000 Honda Odyssey
Sony RCD-W1 2-Disc CD Recorder Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
