Question about Ricoh Aficio CL3500N Laser Printer
Ricoh 6330 bypass tray not working - Ricoh Aficio CL3500N Laser Printer
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: ricoh ap3800
Try sending A4 or letter size to the bypass. if the same problem is risen then you will most likely have a problem with the bypass itself and nothing you have done or are doing.
The other way to check is to set a 11" x 17" in the second tray and try it that way if that goes through then there is no problem with the way you are doing things and the problem lyes with the bypass section.
Please try these and I hope they are of some help to you
Thanks J
Posted on Jan 02, 2008
SOURCE: How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Posted on Feb 13, 2009
  • 1297 Answers
SOURCE: Ricoh Aficio 240W is limited to bypass tray use
Enter into service mode:
1.Press the clear modes key.
2.Enter 1-0-7.
3.Press the clear/stop key for more than 3 sec until the service program menu appears on the touch panel.
Select paper tray setting,and set the new value.
Posted on Aug 02, 2009
SOURCE: Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Posted on May 13, 2010
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Bypass tray locked out for printing
Please the copiers models.The paper tray is selected in the computer.To the Ricoh copiers the by pass cassette selected mannually.
Feb 07, 2012 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Jun 09, 2009 | Ricoh Aficio SP C410DN Laser Printer
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Jan 13, 2009 | Ricoh Aficio 450 Copier
Ricoh ap3800
Thanks J
Nov 20, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
