Question about Vizio E370VT - 37 Edge Lit Razor LED 1080p HDTV
Vizio razor e370vt won't turn on
No picture, no sound, have to unplug to turn off
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
circuitworld
  • 335 Answers
SOURCE: 32'' Vizio LCD no picture or sound
Your filter capacitors have popped due to diodes shorting, P-channel FETs shorting from gate-to-drain. Pull-up resistors have changed value and as a result your capacitors have peaked (popped)....so now the tv is in protection mode to prevent further damage to your tv. Take it to your local shop for servicing, or take it back if its under warranty......
Posted on Nov 05, 2009
  • 8457 Answers
SOURCE: vizio vx32 hdtv no picture or control unplug to turn off
Ur LCD Inverter board is dead.Replaced this board u will get the picture back.It a long board.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board.
Posted on Feb 17, 2010
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Posted on Oct 21, 2010
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Vizio tv has sound no picture
Hi Brenton,
You have sound and no picture. It appears to be a case of backlight failure which is common in LED TVs. The problem is technical and involves opening the tv, diagnosing and replacing or repairing the defective board. Please consult some good local TV tech. Good Luck.
Apr 28, 2015 | Vizio Razor E461-A1 46" LED TV 1920x1080,...
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
Picture problem
i have vizio that turn on, but no picture, and the invarter light is on and it won`t turn off.
Oct 20, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio E370VT - 37 Edge Lit Razor LED 1080p HDTV Logo
44 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
