Question about Kenmore Sewing Machines
Threading a kenmore sewing machine model number 13502
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 11 Answers
SOURCE: How to thread Kenmore 25 sewing machine Model 385
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 22, 2009
How do u thread a Kenmore Sears sewing machine model number 148.12190 serial number 37029
Sears usually has manuals available for download for their machines. Even if your specific model is not available, most machines from the era thread the same or very similarly.
Feb 20, 2017 | Kenmore Sewing Machines
Direction on how to thread kenmore sewing machine 385. Model number 1168291
Perhaps this will help:
Part 1 Basic Sewing Machine Tutorial Kenmore 385 Series
Part 2 Threading the Bobbin Tutorial on Kenmore 385 Series Sewing Machine
https://www.youtube.com/watch?v=f09wuSTtouY
https://www.youtube.com/watch?v=dOWZX6EV3g4
https://www.youtube.com/watch?v=YJj-9Jj_HUw
How to Thread Sewing Machine Kenmore Model No 385 16221 Series
Jul 25, 2016 | Kenmore Sewing Machines
How Do you thread a Kenmore sewing machine model #12116690
Search internet for:
Make + Model + the word "Manual"
Or go to YouTube and search videos for your make/model machine plus threading instructions. Many machines from like eras will thread the same way.
Kenmore sewing machine thread Google Search
Jan 18, 2016 | Kenmore Sewing Machines
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
The thread keeps breaking I tried to thread the way the one person on here discribed it. I could use a manual model # 158 12321
Could you please verify your machine's model number? Don't use the number on the motor; there should be a small plate on the machine itself. I ask because I can't find a model 158-12321.
Aug 17, 2010 | Kenmore 16622 Mechanical Sewing Machine
I have a Kenmore Sewing Machine (old) Model E-6354 that was given to me but it doesn't have a manual so I don't know how to thread it or operate it.
Hi. I tried looking for your manual but am having a problem with that model number. Kenmore model numbers begin with three numbers (like 117 or 385), then a dot, then four (or more) numbers, like 117.1234. But here's a link to a group that specializes in older Kenmores like yours and they should be able to help. http://groups.yahoo.com/group/vintagekenmoressew/
I really love old sewing machines and am really glad to see them used and loved.
Happy Sewing!
Robbie
Apr 28, 2010 | Kenmore Sewing Machines
Getting the Bobbin threaded in the Machine
when this has happened to me, the upper thread has somehow run amuck. check to make sure the top thread is STILL routed properly. It might have nothing to do with the bobbin.
Sep 05, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
