Question about Cannon Woburn 10560G / 10562G / 10565G Gas Range
Replace battery cooker - Cannon Woburn 10560G / 10562G / 10565G Gas Range
How to replace battery in Zojirushi NP-HBC18 Rice Cooker?
Not that exact model, but I have replaced the battery in two others. The unit will likely have four screws in the bottom, possibly some snap-together hooks on the sides. The battery will be on the small circuit board under the display and buttons. It should be a CR2450 or similar sized 3V cell with two tabs soldered to the circuit board. My local battery store did not have exact replacements, but any 3V cell with the proper tab spacing will work. Make sure to note the polarity of the old cell prior to removing.
Mar 10, 2015 | Zojirushi NP-HBC18 Rice Cooker
How do I replace a battery on zojirushi rice cooker
You will probably find (like I did) that the battery is a large (about 30mm diamter and 10mm thick) lithium one that is soldered directly onto the main PCB. You will need to open the cooker (ensure that it is unplugged) and remove the PCB. There will probably be a lot of different size plugs on the PCB which you need to remove first. On my cooker I found that these were all different sizes and/or colours, so the could not be mixed-up. Unsolder the battery from the PCB and solder a PP3 battery connecter in its place. Replace the PCB and run the PP3 connector to a suitable space inside the case (away from any 'live' items). Place two AA/penlight 1.5 lithium batteries into a 3 Volt holder and connect this to the PP3 lead. Then secure the holder in a suitable location inside the case. In future changing the batteries is much easier!!! Note that when you open the case, the screws are on the base of the cooker, and there are also some plastic clips which help hold the case together - pull carefully to release these once the screw have been removed.
Jan 31, 2015 | Zojirushi Kitchen Appliances - Others
How to replace lithium battery on Zojirushi NS-KCC05
how can i change the battery on my ZOJIRUSHI rice cooker
Aug 13, 2012 | Zojirushi NS-KCC05 Micom 3-Cup Rice Cooker
Where is the lithium battery located on a JAE-A18U model?
Removed 4 screws with black plastic on the bottome. Then slowly seperate the lower housing. Lithium battery is located on the electirc diplay unit which has 3 screws. Unfortunately, the battery is soldered on and will require a shop with soldering experience to replace. I'm having the flashing 0:00 issue and my rice cooker is not working.
Sep 14, 2011 | Tiger JAE-A18U 10-Cup Rice Cooker
My rice cooker doesn't work... the clock doesn't work .... just completely no power. so where can I take it to get it fix from australia
The manual for your Zojirushi NP-HBC18 Rice Cooker can be found here:
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nphbc.pdf
Refer to page 12 of the pdf for Troubleshooting and page 13 for Error Displays
It may be that the stored Lithium Battery requires replacement.
Suggest you contact their Customer Service for information on the battery and how to replace and whether there are Service centers in Australia:
http://www.zojirushi.com/support/customer_service.html
Mar 15, 2011 | Zojirushi NP-HBC18 Rice Cooker
How do you replace the battery in this rice cooker??
How to replace battery on Zojirushi NS-KCC05. The question has not been answered. Where to locate the battery. Take off the bottom by unscrewing the screw near the legs? Then what?
Feb 02, 2011 | Zojirushi NS-KCC05 Micom 3-Cup Rice Cooker
New world gas cooker (apex hl 500)
the battery compartment is located right at the bottom of the cooker on the front, slightly to the left. It's a little compartment that houses a aa battery. it's unclips on the right hand side. hope this helps
Jan 31, 2009 | New World 50HLG Gas Kitchen Range
Replacing clock battery on the ecj-b35s
This web site has a photos on how to open the Sanyo rice cooker:
http://www.efsowell.us/ed/SanyoECJ-B35SRiceCooker
The solution shown is to install an external battery pack,
but in the battery looks like a 3 volt Panasonic CR-2354/HFN .
(picture is too blurred to read a part number,
so you should check your own cooker).
http://www.digikey.com carries this part
(listed as P274-ND) for $1.90 plus $7.50 UPS ground service
(only carrier authorized to ship lithium batteries)
I used this battery to repair my William Sonoma SR-MK10S
Fuzzy Logic Rice Cooker which is the same as a
NationalSR-MM10N. I found the Panasonic repair manual at
http://www.usersmanualguide.com/panasonic/rice_cooker/srmm10n
-david
Sep 14, 2008 | Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker
Cannon Woburn 10560G / 10562G / 10565G Gas Range Logo
19 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
