Question about Panasonic Heating & Cooling
I can't heat with the Panasonic bzt g104 612c
Bzt g104
Why would the information panel in my car display, "Low fuel," "shocks inoperable," "service traction control," "do not exceed 80mpn," "service active handling," ect: and fuel gage reads empty?
G104
Instrument panel harness, below the battery tray, on the RH frame rail, ground for SP208 (CKT 851)
Splice Pack, SP208
Instrument panel harness, RH side of instrument panel, grounded to G104 (CKT 851)
G108
Forward lamp harness, below the battery tray on the frame rail
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
The PCM detects a malfunction in the fuel level sensor circuit.
The IPC displays a low fuel message on the DIC.
The check gages indicator turns on.
SERVICE ACTIVE HNDLG
Refer to ABS Description and Operation in Antilock Brake System
SERVICE TRACTION SYSTEM
SHOCKS INOPERATIVE
Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Control
Mite be a good idea to have the vehicle check for DTC'S diagnostic trouble codes if the grounds are good !
This vehicle is equipped with a computer system capable of performing multiple engine and body control functions. Vehicle components such as windows, locks, mirrors, etc. are controlled directly by their system control module. Each system control module communicates with other system control modules on a serial data circuit. The vehicle system control modules are all attached to the serial data circuit that provides the data link communications. This data link, or serial data circuit, provides 2-way communication between various engine and body control system control modules.
I don't
Sep 09, 2015 | 2003 Chevrolet Corvette
Nokia ce0168 code needed immediate pls
Are you asking for a network unlock code? CE0168 is not the model name of your Nokia phone.
The free standing CE Mark can be used to identify Telecommunications Terminal Equipment
(TTE) that meets either the Low Voltage Directive, or the EMC Directive, or both.
This product carries the CE Mark, with the Notified Body Number
TTE, Notified Body, Name Country, Notified Body Number
NSAI, Ireland, 0050
DGT, France, 0165
IGT, Italy, 0166
HDTP, Netherlands, 0167
BABT, United Kingdom ,0168
TELESTYRELSEN ,Denmark ,0170
BZT ,Germany, 0188
DGT, Spain, 0341
COMLAB, Norway, 0436
IBPT, Belgium, 0468
So you need to specify the exact model of your Nokia phone to get an exact solution. Once you have found out your Nokia phone's model name, you can visit WickedUnlock.com and get the accurate unlock code at affordable cost with an easy unlocking guide. Good luck.
Nov 28, 2014 | Cell Phones
Hi sir my mobile lock model no-ce0168 samsung
CE0168 is not the model number of a mobile phone. The free standing CE Mark is be used to identify Telecommunications Terminal Equipment
NSAI, Ireland, 0050
DGT, France, 0165
IGT, Italy, 0166
BZT ,Germany, 0188
DGT, Spain, 0341
IBPT, Belgium, 0468
So, you must specify your exact mobile model to get a best solution. Once you knew the mobile model, you can visit Unlocking4Free.com to get the free unlocking code. If your mobile model is not available in the supported list, you can visit Unlock-Zone.com to get the accurate unlock code at affordable cost. Good luck.
Oct 06, 2014 | Samsung Cell Phones
How do i fix electrical problem on my gmc?
https://s1.postimg.org/635jzlm5zj/headlights.jpg
Click on the link.
As you can see, the hi--lo beam on the right side uses one ground. The hi and low beam on the left side use a different ground. If I suspect a ground problem, I use a redundant ground to see if it helps?
Oct 31, 2017 | 2003 GMC Sierra 1500
Trouble codes chevy p1518
The first check should be done to the TAC module to make sure that none of the wiring near the Control Module is damaged due to chaffing. If the wiring and module appear to be in tact, the procedure below is recommended to correct the P1518
Condition/Concern:
Customers may have a concern of lack of power and engine light on. DTCs set will almost always contain a P1518 and may contain any of the following (P1516, P2108, P0220, P0120, U0107). An improperly torqued TAC module ground may be at fault. The Ground is listed as G104 on TAC module schematic which is incorrectly labeled on SI document ID 855376. The correct ground is G103. The locator for SI states that G103 is located on the left hand side which is incorrect. However, there have been field reports stating that G104 has also corrected this condition. G104 is a horizontal bolt in the rear of the left head and extremely difficult to reach. G104 should also be tightened at the same time.
There have also been field cases where ground G110 on the outer drivers side frame rail caused a P1518 code and an intermittent connection at splice 102 on the intake.
All published SI diagnostics should be followed in addition to following the recommendation listed.
Recommendation/Instructions:
Tighten ground G103 located behind the right cylinder head (passenger side) just below the head and mounted into the block. The ground uses a 13 mm bolt head mounted vertically to the engine block just above the bell housing.
May 17, 2013 | 2001 Chevrolet Suburban
Doesn't print black text despite full cartridge
It may be problem in print head or purge unit, bzt first did you try with print head cleaning under printer properties/preferences?Try few times, if not, remove ink crg., remove print head, take lint free clotch and moisture it with destilled water and put the print head on it few minits, then dry it with anoter lint free cloth.Put it back in and repeat the head cleaning and nozzle check.
If not helpfull replace print head and purge unit with absoerber
Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I have a 2005 GMC 2500HD code P1516, already replaced APP. Still dies, reduce engine speed comes up. What is the next step?
The Throttle Actuator Control (TAC) / throttle body type trouble codes, may be caused by a loose wiring crimp at the throttle body connector, or a broken throttle body circuit.Inspect all related throttle body terminals for a loose wiring crimp. The loose crimp may be difficult to find, and the poor connection will be between the terminal and the copper strands of the wire. Wiggle test the individual throttle body circuits to see if the concern can be duplicated.
Inspect the related circuits for broken wires inside the insulation. The outer wire insulation may look fine, but the internal copper strands may be partially broken. Breaks in the wires usually occur within 1 to 4 inches of the throttle body connector. Wiggle testing may also induce a trouble code to set.
On C/K trucks complete SI procedures for voltage drop on grounds G103 and G104. Grounds G103 or G104 may be loose or corroded. If a terminal crimp or a broken wire has been found, repair or replace only the circuits involved. There is a throttle body pigtail connector available through GMSPO, post back with what you find.
Dec 15, 2009 | GMC Sierra 2500HD Cars & Trucks
My 03 chevy 1500 randomly goes into redueced engine power sometimes u can turn it off and restart it and it will be fine but other time it will be messed up for hours, its have a p1516 and p1518 but we...
check for an obvious loose ground at G103 located next to the right cylinder head just below the head and mounted into the block. Also, check G104 located behind the left cylinder head. Then verify all electrical connections at the throttle actuator control module.
Jun 28, 2009 | 2003 Chevrolet Silverado 1500
Philips Magnovox FP5251 G104 (1995 model)...
if you can remove the screen you probably need to clean the mirror. if that is the case, don't use windex use a very mild solution of dish liquid (3-4 drops to the quart) then you will have to wash it several times with that. any harsher solution will remove the mirror surface. use a very soft , lint free cloth but not terry material. your bath room mirror has the "silver on the back side this one if it glass has the "silver on the front. if it is mylar don't press hard or it will streach and distort the pix. good luck
Aug 03, 2007 | Philips Magnavox 27MS343S 27" TV
Heating & Cooling Logo
328 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
