Dudley cyclone letter lock won't open - Computers & Internet
I bought a sentry safe DH-074E, I know little about safes, except for they are valuable, at the flea market, for $30.00,with no pass code. How can I get It open, HELP
Good luck with that. You are hoping to get a code that any potential thief wants to know for a different reason. You may choose the approach that is common for Dudley locks, that involves sampling the code until it opens. This can be done about 100 times until you get an approximate code. However, I presume this safe has a more precise method of accepting combinations. Again, good luck. Don't lock anything valuable inside it until you find the code.
Feb 02, 2015 | Home Security
2000 buell cyclone fell over and won't shift
Bent shift fork - requires internal service work. Costly and time consuming. Don't let em fall over to avoid this sort of problems with ANY bike.
Apr 01, 2013 | 2000 Buell M2 Cyclone
Dyson DC14 animal dust bucket doesn't lock back in
From what you've described, it sounds as if you may not have your clear bin and cyclone pack assembled correctly. Please check you have these parts correctly fitted together - it may help to take a look at the DC14 user guide:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
This should resolve the issue, but for any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Jan 17, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
2001 Ultra classic 79,000 miles. Cruise control quit on long trip. Radio auto volume stopped. Electric trip odometer inop. No
Hi Dudley, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Nov 20, 2011 | 2001 Harley Davidson FLHTCUI Electra Glide...
I set my new code but it won't open.
If you remember the first letter/number you're still in luck. What you need to do is start off with that letter. If you know what you tried to set, ex. ATE
Work with
A
A, D, E, H, J, L As for the last number/letter, all you have to do is keep spinning it right and you will hit it.
For me, I tried fooling around and setting ALT
However, when I was entering the new combo, I turned 3times or more right when key was in to A, then a full circular left turn past A to L. From L, I turned the same direction 4 clicks to T and locked it. I realized I entered it wrong when I locked it. How these locks were designed isn't that complicated. It consists of 3 different turns. Right, left, right. Right to A, left to L, right to T. When I had entered, right to A, left to L, and left again to T. It automatically makes the second letter/digit the same as your first letter/digit. I cracked my lock trying all combinations of A,L,T. Writing a list helps. But I also suggest your write down a list of your first digit twice.
A, A, L A, L, A
A, L, T A, A, T (That's what my code was after incorrectly trying to set it as "ALT")
However, this is only one method. When I had purchased the lock a year ago and set a combination. I approached it with a different method. The first one as I mentioned. I had tried to set EAT to test. The combo ended up being a letter or two off in the combo itself. So my cracked combo was not EAT but something _AT or EA_ or E_T. Combos usually aren't off by a whole lot. I was going to throw my lock away and buy a new one, but I cracked it :) I know this is alot about my own experience, but don't give up! I was planning on solving it, but I did it within 10mins! Not so tough !
Aug 24, 2011 | Master Lock 1590D Set-Your-Own Combination...
Have entered the proper id and password however won't let me open my e mail
Do you have caps lock on? Are you sure you are putting the correct letters capitalized, or are holding down shift while trying to type numbers. Maybe not holding shift to type characters.
Jul 21, 2011 | Yahoo Mail
My olympia electric typewriter is always on capital letters no matter how i unlock the keys/shift...won't go back to small letters.
You didn't give a model but there should be a key that says above or on the front of it caps or caps lock the code and that key should do it.
DickyO
Jun 24, 2011 | Olympia Office Equipment & Supplies
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
Failed to find phone book for dudley england require list of welsh/ welch names & current addresses.
I don't know anything about Dudley, and there are two areas called Dudley. Try www.192.com. It did come up with about 8 people with the Welsh surname in one of the Dudley's.
Carl
Apr 22, 2010 | Lands Phones
Wharfedale L19T11W-C (hack codes)
Get in contact with a Wharfedale authorised dealer to do this one. It requires a Blackberry interface, and specail programming, if this set will accomodate the change...accordianman
Feb 27, 2008 | Televison & Video
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
