Question about Kenmore Freezer 5.0 cu. ft. Manual Defrost Upright Freezer
5.0 black & decker chest freezer seems to be leaking very slowly out of the bottom it has ruined my floor where it sat.i moved it and i just moved it and checked it again and there are no puddles
5.0 black & decker chest freezer seems to be leaking very slowly out of the bottom it has ruined my floor where it sat.i moved it and i just moved it and checked it again and there are no puddles but you can feel how damp it is
peyton32034
  • 410 Answers
SOURCE: Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Posted on Dec 20, 2007
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: freezer leaking and icing underneath
The plug may have been mashed and deformed.
Replace it.
Posted on Mar 12, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My kenmore mod#2539183511 chest freezer
Sorry to read about your problem. you can have many different problems.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 02, 2011
  • 884 Answers
SOURCE: kenmore freezer leaking green
It's not refrigerant. Refrigerant would have evaporated straight away. What did you have in the freezer when it went off? It may be refrigerant oil, in which case mop it up with paper tissue and clean the area with detergent. It's no more toxic than any other oil.It's most likely to be excess ice/frosting leeching from inside the cabinet. Again, mop up with tissue paper.
Posted on May 02, 2012
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
Black and decker chest freezer on frost in the upper half of the freezer, the other half going down to the bottom is just cold with no frost and also the top of the inner part of the door is making ice.
You may have a leak of refrigerant, you may have a warm air leak when the lid is closed, or you may just need to defrost it manually. use heat ONLY, do NOT poke at the ice or frost with anything
Oct 10, 2010 | Freezers
Black & Decker BF53 Chest Freezer wont freezer after moving to another state. It worked fine and now its just freezing to a frost is all. I'm scared my food is going to spoil. Bought it second hand and...
dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Jul 09, 2010 | Freezers
My kenmore 19.7 cu.ft. chest freezer is not running and the compressor is hot
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Apr 25, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Condensation forming on the bottom of freezer
Referred back to the manual and installation requires 3" of space on sides and back. Moved the freezer to comply with that requirement and problem seems to be resolved.
Jun 05, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Dec 26, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
