Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
I need to buy a output ic, where can I buy one for good price?
Where can I buy an output ic for a resonably price and is there anything else I need to buy, since I blow the output ic?
    New Friend:
GO TO AMAZON
Posted on Dec 03, 2013
Remove resonator from exhaust
If you always buy Walker Exhaust products
you won't have these questions.
You provided no info or even a vehicle & you
can go to walker or any auto parts store site &
see what is avail & the layout for installation
I hope you have actually been under the vehicle
& made notes of what is needed & even some
measurements.
If your not intending to reinstall the resonator, then your
on your own to redesign the system,not all that hard,you
can buy & fabricate anything you have skills for.
Jul 04, 2013 | Cars & Trucks
JVC AV-27820 turn on the a white line accross middle
Hello
Total failure of vertical sweep occured whic your JVC TV. There are mainly two resons for this fault.Loose soldering terminals of the vertical output IC is the first one. The second one is of failure of the vertical output IC itself. You have to locate this vertical IC. It can be located at the main board. Vertical IC will be screwed on to a metal heatsink to radiate heat from it while it works. You can identify it very easly, if you have knoledge in electronic circuts abd printed circuit boards.
Resolder all the solder terminals of this IC first, by applying a little more solder; without making any solder bridge short in between the close adjecent solder terminals, and see whether it helps you. If not replace it with same type and number. OK.
Oct 08, 2011 | JVC AV-20220 TV
JVC 27D201 picture gone except for one bright line across the middle, .5 cm. high
Hello
Vertical output section of your TV is faulty. There are mainly three resons for this fault. The first one is of faulty electrolytic capacitors at the vertical output section circuit. The second one is the vertical output IC. The third one is of loose solder termitals of components at the vertical output section. Resolder most of the solder terminals of this section by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. If this does not help you, replace all electrolytic capacitors at the vertical output section circuit of your TV. There will be 6 0r 7 of them the most. Replace all of the at the same time. They won't cost more. If this does not hlep you, replace the vertical output IC. OK.
Aug 26, 2011 | JVC AV-27D201 27" TV
Cheap cold air intake for1995 jeep grand cherokee or howdo i mak1
I would suggest going to a junk/recycling/wrecking yard and buying one. they are often a fraction of the price of a new one and just as good.
Mar 28, 2009 | 1995 Jeep Grand Cherokee
Proccesoor Ic
Usually if a problem of a monitor is the main IC itself, it is recommendable to buy a new one (since the price of the main IC is almost the same price as a new one itself. (depending on where do you reside) in our country, we consider buying a new one when the issue is the IC itself since here, the price of the IC is almost the same price if you buy a new one (about USD 100 for a new LCD monitor, while a main IC costs about 70 to 90 USD)
Mar 04, 2009 | Audiovox Computers & Internet
CONVERGENCE OUTPUT I.C.
Nextag and eBay are turning up nothing for this model. In comparison to other manufacturer's prices, the quoted price is not "unreasonable." Projection TV repairs are certainly not cheap. Sorry.
May 24, 2008 | Samsung HCN653W 65" Rear Projection...
How do I,
in my country we do change the battery but now a days you can buy a new one or compatible with a good resonable price.You can check it from here
http://www.buy-laptop-battery.org/
takecare.
May 01, 2008 | HP Pavilion zd8000 Notebook
Repair
$250 is a bit tough if you are sure the IC is only $27. It is not clear from your post if your microprocessor works alright. If your display and other functions were okay when you gave it to the service guys, your micro is okay, in that case the only other costly thing in your board is output ic. Getting a board from Pioneer isn't easy, they don't sell boards in shops, they provide it to their authorized service ceneters only. You can try finding a friend who is aware of the boards and have this checked.
Jan 25, 2008 | Car Audio & Video
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
94 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
