Question about Paragon 8145-20 Defrost Timer
How to program a legrand 04761 timer?
16A 240v
16a legrand bollard timer switch not switching off.Please advise how to reset. Thanks
If the timer is electro-mechanical, it may be hanging at the turn off point.
Jan 04, 2017 | Legrand Hardware & Accessories
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
How do i get a legrand 412641 to change from chanel one to chanel two
Looking at product manual, it is unclear how you toggle between channels.
There are 4 buttons. Menu, C1-, C2+, and OK.
The menu button: looks like you press repeatedly to scroll through menu items. If you hold down more than 1 second, it goes to operating display.
To get to each channel... generally, it appears you either
.... Press Menu to scroll down to PROGRAM, then click OK, then use press menu to select Channel 1 or Channel 2, then click OK
... OR you Press Menu to scroll down to PROGRAM, then click C1 button or C2 button to select channel
Gene
Feb 24, 2015 | Legrand Hardware & Accessories
The 64B 240v 50Hz 16A theben timer is not turning lights off
Copy following link for analog 24-hour timer:
http://waterheatertimer.org/How-to-set-timers.html
Is this new timer, or older timer with worn-out trippers?
Or is this the theben digital timer.
Add a comment and describe timer in detail for more possible assistance
Apr 20, 2013 | Hardware & Accessories
Legrand03740 intstuctions
Legrand 03740 vertical analog timer instruction manual with wiring diagram:
http://waterheatertimer.org/pdf/Legrand-03740-timer-instruction-manual.pdf
Nov 20, 2012 | Hardware & Accessories
I have a 16 amp Legrand electrical timer cat 037 30 on my hot water system. How do I program it?
Legrand 037 30 is vertical analog timer similar to hagar EH 010
Open following link for illustration how to set and wire timer.
http://waterheatertimer.org/images/EH-010-2-2-500.jpg
Hours of the day appear on timer dial as you rotate dial around.
Hagar timer you push segments left for ON times, and right for OFF times.
To set current time, manually rotate 24-hour timer dial until current time lines up with mark.
You can also move some of the segments to the right and leave rest of segments to the left.
Then manually rotate timer dial several rotations with thumb while listening to the hot water system turn on-and-off, or use tester to test power at terminals 3 and 4 or use tester at hot water system.
If timer has override lever, then move lever to each position and repeat test by rotating dial with each switch setting.
Jun 30, 2011 | Hardware & Accessories
How can i set the on and off of my legrand timer switch
You posted under GE timer, but say you have Legrand, and don't include the model number or type of Legrand timer.
1) The only Legrand timer I have in my files is the RT1 countdown timer
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#RT1
http://waterheatertimer.org/images/RT1-timer.jpg
To set RT1, you push one of the buttons, and fan-or-light turns on for a duration of time, then automatically turns off. Use the large button as ordinary light switch.
2) Legrand also makes commercial line of timers, including din rail timers and pin-type timers
http://www.legrandcommercial.com/control_timers.htm
3) If this is not your timer, add a comment and include in-focus photo of your timer for possible identification.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 26, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Paragon 8145-20 Defrost Timer Logo
315 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
