Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Need to replace microswitch that engages when handle is lowered on dyson dc17 part # dy-916405-01
SOURCE: How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Posted on Apr 04, 2009
SOURCE: roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Posted on Aug 09, 2009
Vac Belts
  • 701 Answers
SOURCE: My dyson DC17 makes a loud noise when i tip the
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Posted on Nov 28, 2009
  • 4 Answers
SOURCE: Power shuts off on my dyson dc17 animal
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....
Posted on Jan 04, 2010
  • 53 Answers
SOURCE: How do O replace the belt?
This video should help you out.
Posted on May 31, 2010
I need to know how the upright microswitch is installed on a dyson dc17
It fits into a little slot in the motor compartment, when the handler is reclined it activates the switch to supply power to the brush roll motor.
Sep 21, 2017 | Dyson Vacuums
Dc17 recline
The manual can be found here:
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc17_opmanual_usa%20pdf.pdf
Per page 9 (and this is consistent with every Dyson manual I've seen for uprights), you put your foot on the lower assembly and pull back the upper one. If it's really hard to pivot, even after you get it back, I'd start with just doing so with the vacuum off and move it through it's full range of motion several times to see if it eases up. Also check that the lower spot where the accessory-tool hose clicks into the lower part of the unit if completely set into place. Some manuals have mentioned this as part of troubleshooting.
Good Luck!
Aug 22, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Replace bearing on dyson dy-916217-01
I have a bad motor myself. The bearings make loud noises and the wife is on me to fix it. I can only replace the entire motor because the bearings are not available that I am aware of. The motor runs about $50, cheaper than having them fix it. Dyson does not have parts listed on their pages but you can Google the vacuum/parts and find them. Working on a Dyson is like working on an car. You have to take everything apart to get to what you need to replace. Good luck.
Nov 08, 2013 | Dyson DC17 Brushbar Motor Assy 916217-01
Why would my dyson dc 17 brush motor be extremely loud, but sound normal when brush is not spinning?
could be the bearings on the end of brushbar need replacing,or it may be the clutch needs setting , lower the handle down to the floor then up again do this about three time to reset clutch....
Nov 13, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar stays engaged when handle of dyson animal 17 is in the up position
Hi Richard,
I'm sorry to hear you're having difficulty with your DC17. The issue you've reported sounds very unusual, and we'd appreciate the opportunity to provide further assistance. Please give our customer Helpline a call on 1-866-693-9766 - alternatively, if you email us at askdysonUS@dyson.com , someone will be in touch as soon as possible to discuss this with you.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a dyson dc17 animal. When you put the handle down, it is very loud
When you lower your DC17's handle into the vacuuming position, a second motor which powers the brushbar will switch on, which will make the machine sound a little louder than when it's standing upright.
However, if you're concerned that the noise the cleaner is making is unusually loud, I'd encourage you to get in touch with us directly - we'll be able to run through some troubleshooting checks over the phone to help resolve this.
You can reach us on 1-866-693-9766 - or if you email your contact details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Feb 25, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 power on/off button will not engage when pressed
The on/off switcdh underneath the button sounds like it's faulty and will need replacing. I would suggest caling Dyson in your country with the Serial No of the unit for guidance.
Mar 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson animal
called dyson they told me to turn the vaccum on and off 5 times, lower the handle to the floor when it was off. Now try the vaccum again and it worked. This is somekind of reset.
Thanks Paul
Jan 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
53 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
