Question about Acu-Rite Acurite Wireless Weather Thermometer 604
Acu rite thermo senser RNE822TX
Outdoor senser light does no come on.Instaalled new batteries,whats wrong?
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
Posted on Dec 01, 2010
SOURCE: I need instructions for my Model 00972 Acu-Rite
flashes continuously the time and the outside timp
Posted on Jan 09, 2011
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
Posted on Feb 03, 2011
fixya-surfer
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer (model 00754)
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
Posted on Mar 02, 2011
fixya-surfer
  • 73 Answers
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
Jan 22, 2010 | Acu-Rite Audio Players & Recorders
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
280 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
