Question about Furniture
Hja6900 wine cooler
How can I switch it off apart from unplugging it?
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 1122 Answers
SOURCE: WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Posted on Nov 11, 2008
  • 286 Answers
SOURCE: U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Posted on May 18, 2009
mrbobfixit
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
  • 26 Answers
SOURCE: I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Posted on Jul 31, 2012
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Everstar hdwc35
Do you still have your Franklin HDWC35 wine cooler?
Feb 08, 2014 | Furniture
Jul 31, 2012 | Furniture
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
Moved cooler and wont restart
try leaving unplugged for a couple hours then plug back in
May 18, 2010 | Avanti EWC28 Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Temperature setting doen not work
rsteiner10,
Welcome to Fixya.
You said, you have the Magic chef wine cooler and it is not cooling. I unplugged it when the temp was reading 78 degrees!!! It was cooler to unplug it!! Does anyone know where you can get this repaired?
here in our fixya site there are serviceres from all round the country.
click on Browse the Repair Directory an you may find a serviser in your area.
Thanks
let me know you found some one!
Huuum
Please remember to leave me a rating before you leave me!
Oct 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
