Question about GE WBSE3120B Top Load Washer
Washer stuck on Final Spin
Washer will not get off of the "Final Spin" stage, even if the load size knob is turned to reset. I tried to let the machine run on Final spin to see if it would reset itself, but that did not work. I hope someone can help me fix this, because it is not under warranty anymore.
  • Anonymous Dec 13, 2007
    washer got stuck on final spin stage,tried resetting but dont worked, tried many times letting run on final spin, to see if it would reset, but did not work, what should i do?
    Problem Solver:
  • 15 Answers
Sounds like a bad timer to test this you need a multimeter to check voltage to the advance motor if so equipped.
Posted on Oct 10, 2007
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
Won't spin, just agitates. Clothes and water still in machine !!
Glad to hear of progress.Pump could be faulty. 1st you need to check nothing is stuck in the pump ie..coin, next make sure the filter is clean, now is the pump blade free to turn by hand if not investigate why. If all okay replace pump if satisfied there is no blockage and water is flowing to the pump,worthwhile at the final stage to make sure final drain hose to waste pipe is clear..Good luck if I can help anymore please ask...
Nov 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Dec 13, 2007 | GE WBSE3120B Top Load Washer
GE WBSE3120B Top Load Washer Logo
238 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
