Question about InFocus IN5534 Projector
Projector Fan Failure - InFocus IN5534 Projector
Fan failure in acer projector
Take it out, measure it, buy another one, and splice it into the old plug.
Mar 31, 2014 | Acer Office Equipment & Supplies
The projector power, lamp temp lights come on no fan
Please check the filter door switch or if the fan as if the fan does not work there is an error and so the lamp will not be powered.
Check the power to the fan motor, check the lamp for failure.
Dec 03, 2011 | Sharp XR-30X Projector
The fan has stopped working, and the projector has shut down and will not turn on. The bulb is still OK.
The thermal fuse behind the lamp module has opened (usually due to a high internal temperature). On some occasions, this is caused by a fan belt failure. Because this involves primary voltage, I would recommend you take the projector to an authorized repair dealer.
Nov 09, 2010 | Kodak Carousel 4400 Slide Projector
When projector is powered starts beeping then display fan failure
http://www.givemefile.net/smanuals/projectors_home_entertainment/toshiba/file/31174.html
There is a service manual, use the troubleshooting procedures, and you should be able to find out whats wrong. It could be your thermal fuse, or your lamp, or the ballast, so you will have to troubleshoot to find out.
May 24, 2010 | Toshiba TLP-X2500 LCD Projector
I get the message of fan failure in my optoma hd 80 home theater projector, is it fixable, needs a replacement fan, etc.?
first vac and clean vents for proper air flow if still coding with unit unplugged remove cover and check fan for blockage if good and still fan code test fan, if bad fan is replaceable most electronics or some computer stores should have it if u want to diy can use serial&model number of projector or numbers on the fan
May 18, 2010 | Optoma HD80 Projector
The message on the projector says ''fan failure''
You have a problem with your fan/s, it will not start so it has either got a fault with it or the sencor has been knocked.
Jan 31, 2010 | Dell 4100MP Multimedia Projector
I just replaced a power supply, it has one fan instead of 2. Works great but now I get an error message saying it can't find the fan (which I'm no longer using), how do I get rid of the message?
replace the fan. it needs all the fans the projector was designed with to properly cool it down. without all the fans, the lamp will overheat and cause premature lamp and projector failure. the fan has 3 wires- ground, power and sensor. if the fan spins too slow or not at all, the projector will shut down to prevent damage.
so, replace the fan.
Jun 30, 2009 | InFocus LP70+ Multimedia Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
Fan failure erratic
Lubeor replace the fan.If you cannot do this, take it to a repair shop.The fan is monitored because without it the projector will melt down a la china syndrome
Mar 24, 2009 | Optoma EP730 Multimedia Projector
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
InFocus IN5534 Projector Logo
18 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
