Maytag washer se7800
How old is this unit and are they repairable small unit dryer -is it 220
4 Suggested Answers
  • 25 Answers
SOURCE: does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Posted on Dec 22, 2008
CRTN
  • 716 Answers
SOURCE: Maytag LSG7800AAW Dryer not working
Its Either One Of Two Problems If Its Electric Its The Thermostat but if its gas it can be either the thermostat or the igniter. If its gas you can watch the igniter or listen to hear if its lighting. If it lights its the thermostat cause if the thermostat is malfunctioning it will turn the gas off when it doesn't detect the flame. It turns the gas off to prevent your home from filling with gas. Hope this helps.
Thanks For Choosing Fixya
Sincerely,
Michael Scott
Posted on Jul 07, 2009
ercupa190
  • 12223 Answers
SOURCE: Does this combination unit need both a 220 volt for the dryer and a 110 volt for the washer?
yes in that way work. Is o.k the power for dryer will be more strong that the washer, The reason is heating elements fro dryers.
God bless you
Posted on Sep 29, 2012
Is the motor blown when dryer only clicks when turned on?
Rarely is it the motor. Check power to the unit, Full 220? Otherwise it is in the safety management... The only way to resolve is to follow the power through the system. Switches, limiters, and mostly connection are suspect.
If you are not absolutely 100% comfortable working around 220 volts, do not attempt this surgery. A small mistake can kill you.
Apr 17, 2015 | Maytag Dryers
Maytag electric dryer LDE410 will not start. There is 220 power. Power goes through the switch. Where is the fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2011 | Maytag Washing Machines
Just bought a new (old) house and the Maytag stackable w/d stayed. The dryer doesn't heat up at all. We've cleared the vents, but still no heat.
Check that you have 220 volts. or see that the timer is not set to Air Fluff ( no Heat)
you may have a bad thermostat, or a broken
heater coil. or a broken belt.
May 26, 2010 | Maytag LSE7806A Top Load Stacked...
I Like to know in what vltage that dryer works? 110 or 220?
this is 220, only small apartment sized machines are 110.
the 220 supplies one circuit for the heat and one for the motor to turn the drum
Aug 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have a old Maytag Stackable W/D combo breaker tripped and I cant restart. Is there a reset breaker on the unit? If so where is it?
If it has one it will be a small red button toward the rear of the motor. You may also want to make sure that "both" fuses are good in the circuit box. 220 volt machines use 2 fuses as opposed to the 1 for a 110 volt machine.
Jun 22, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag washer/dryer single unit stacker that works fine except the dryer does not give off any heat at all.
Start with resetting breaker dryer tumbles with 110 but needs 220 to turn on element. If still no heat might have a bad element.
Jul 09, 2008 | Maytag Dryers
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
