Question about Mr. Heater MH170FAVT 125,000-170,000 BTU Propane Forced Air Heater
Can I run a 30 lb tank on a heater rated for a 100 lb tank
2 Suggested Answers
  • 3280 Answers
SOURCE: My Mr Heater Buddy heater 4000 to 9000 btu unit
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Posted on Jan 30, 2011
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
20 lb tanks
Yes you can use a 20lb tank to run the heater. I purchased a adaptor hose it hand screws into heater & screws onto tank works fine. Bought the adaptor hose at HD.
Custom Contractor
Jan 01, 2009 | Dyna-Glo Double Tag-a-long Heater
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
HEATER WILL NOT START
Are you using the correct size propane tank? The larger heaters require a 100 lb. tank.
Nov 21, 2008 | Reddy Heater-30-55,000 BTU Variable
Glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Oct 19, 2008 | Desa International Blower Glow Warm Wall...
Heating & Cooling Logo
22 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
