Question about OKI C8800dn Led Printer
Reset the drum counter of oki B401 - OKI C8800dn Led Printer
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
Shah_Sheh
  • 81 Answers
SOURCE: how to reset black drum counter OKI C3300
The consumable counters are aotomatically reset on the OKI C3300n models.
If the printer has a message displayed or you need more assistance leave a comment
Posted on Sep 15, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
SOURCE: resetting image drum after replacing for oki b4600
Posted on Oct 30, 2009
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
Oct 07, 2009 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
I would like to reset the drum counter of my OKI 8800
You need to insert a 1/16A fuse into the drum and let printer blow it thus resetting the counter. Don't use fuses with the higher rate - they can easily blow your printer instead! Much more expencive that putchasing a new drum. By the way - 20k at continuous printing, meaning print jobs are as big as 100-200 pages each. The less pages per job the sooned drum life ends up.,
Mar 05, 2009 | OKI C8800dn Led Printer
Reset Counters
There is no known way to do this!
Nov 05, 2008 | OKI C5400 Laser Printer
Okifax 4580 oki "change drum soon"
1st replace drum if needs to!than press select function button!counter button,new drum reset select yes than start button should reset!
Jun 17, 2008 | OKIFAX 4580 Plain Paper LED Fax
Okipage 8w print drum
To reset the drum counter on these it can be done by this
link to oki 8w Image Drum Cartridge instructions
http://my.okidata.com/man-8w.NSF/MOCContents/5577D9A2FD2AC576852566C100507580?OpenDocument
or if I explain it, go to printers and faxs on your pc find the oki icon for your printer right click it and propertys.... go to printing preference tab, look in there....
If you are having image problems with new drum, I doubt any reset will help.
Post back any issues or check link below chapter 5
http://my.okidata.com/man-8w.NSF/InsideUsersManual?OpenFrameSet
Nov 13, 2007 | OKIPAGE 8W Led Printer
OKI C8800dn Led Printer Logo
1,204 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
