Question about Health & Beauty
Invacare mp6 joystick got wet now wont turn on ..what do i do?
2 Suggested Answers
  • 175 Answers
SOURCE: I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Posted on Jul 08, 2009
Pronto M94. Why doesn't the power button shut off?
The buttons on the joystick wear out on the bottom of the button. The bottom of the button has a conductive material that touches a circuit board. The buttons can be replaced. The buttons are all one big sticker than can be peeled off and a replacement stuck back on. Do not remove buttons until you get what Invacare calls a Joystick Overlay. Invacare will need to know the exact joystick to get you the correct Overlay.
Sep 01, 2015 | Invacare Health & Beauty
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
What do i do..mk6-mpj invacare joystick got wet and wont turn on
Hi, you can send it to me for testing , free , you only pay for the postage back...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Mk6 mpj joystick got went and wont turn on
Hello,please visit:www.Invacare.com & where better to be (the Manufactures).I hope this helped,Colin
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
I was riding in the rain and now my Invacare power wheelchair isn't working properly. Is there a way to reset it, dry it out, or get it working properly again?
Sorry the joystick doesn't like rain or coffee or wet conditions and you will have to have it replaced. Next time carry a wally world bag with you and put it over the joystick to keep the moisture out. you can still steer and use the buttons through the bag Hope this helps
Mar 19, 2011 | Invacare Pronto M51 Power Wheelchair
Batterys charged. I turn switch on. all the lights come on. Joy stick doesn't do anything. Pronto m91 (trulffes@asisna.com)
truffles e-mail me at lennieg2000@yahoo.com. I need to know if you are getting any flashing lights on your joystick and are you hearing the brakes click when you move the joystick. Thanks
Oct 18, 2010 | Invacare Supply Group Invacare Pronto M91...
One of my residents has a Pronto M91 Sure Step and it turns on, the horn button works, the speed buttons work, but it WILL NOT turn off. Please help me. Would that mean I need to change the joystick...
just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
Jul 30, 2010 | Invacare Supply Group Invacare Pronto M91...
Joystick in programming, inhibit and/or charging modeand chair will not run.
This is usually due to either the joystick getting knocked off center or a fault in the control module. If the joystick has suffered a hit such as somebody falling onto it while getting in the chair, or running the joysitck under a table or counter-top(happens often), it knocks the alignment off so that the controller thinks that the joystick is activated, and it will prevent the chair from moving until it is back in its proper location. Examine the joystick for signs that it has suffered a trauma such as the rubber boot being torn, dents on the cover, paint from a collision, etc. Invacare is going to charge you about $1,300.00 for a new joystick, or, you can try sending it to a repair shop. I found one here that I used once and it turned out cheaper...by a lot$. Here's the link.
Keep in mind, it may also be the controller. The only sure way to tell is to swap out the joystick with a known good one, and see if it fires up, if not, then it's the controller. Get your wallet out. I don't know of anywhere to go but to Invacare for the controller. You don't say what kind of wheelchair it is, but if it is one that the controller is built into the joystick then the link above should be able to fix it. If the controller is separate and located in the base, then you have to buy a separate controller from Invacare. To tell, the all-in-one controller will have a very thick chord running from it down into the base; about 3/4" diameter. A separate joystick and controller-in-base will have a smaller chord, about pencil-sized running down into the base fronm the joystick, and will lead to the controller in the base. Good luck.
Oct 07, 2009 | Invacare Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
