Question about Pioneer PD-M426 6-Disc CD Changer
Tray locked on pioneer axd 7305 - Pioneer PD-M426 6-Disc CD Changer
Does anyone have a manual to know how to program pioneer remote axd 7247?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
May 22, 2016 | Pioneer Remote Control AXD7247 p/n:AXD7247
Could anyone tell me what remote control part numbers would be compatible with my Pioneer receiver, model vsx 2014i? The AXD 7412, looks like mine did, but I'm not sure if it would work? Other mod
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
May 15, 2012 | Pioneer Televison & Video
I just got a Pioneer SD-532HD5 and I thought it came with the original remote, apparently not. I have a Pioneer AXD-7430 remote and I cannot get it to work and menu type functions, only power channel and...
I would have thought a remote controller would have been included, tight shop!
The AX type won't work due to the wrong codes. A good quality "one for all" should do it.
Hope that helps.
Jan 25, 2011 | Televison & Video
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Tray lock on pioneer
press and hold stop button on the front apnel on ur dvd palyer ur palyer will resetting
Jan 26, 2010 | Pioneer DVR-225-S Pure Cinema Home DVD...
Message on screen SV-DV77, tray lock. Can't open anymore
Solution found on the internet:
Just press the on/off button for about 8 - 10 seconds and the tray will open.
Dec 06, 2009 | Pioneer Audio Players & Recorders
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Some buttons on the pioneer axd 7305 have to be pressed down realy hard to make them work
I know what is the errors, but I do not know how I shall arrange it. volymbuttons on my remote aint working not but if I move up some of the rubber buttons at the sensors the volume works . Perhaps it could be some magnetic on the rubberbottens or so..
Oct 10, 2009 | Televison & Video
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
Jan 19, 2008 | Pioneer HTZ-77DV System
Pioneer PD-M426 6-Disc CD Changer Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
