Question about Canon MF3110 All-In-One Laser Printer
Scanner mf3110 for win 8.1 - Canon MF3110 All-In-One Laser Printer
Mf3110
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf3110?selectedName=DriversAndSoftware
Apr 21, 2012 | Canon MF3110 All-In-One Laser Printer
Scanner not working
if you can copy then your scanner is ok. If no...first clean your scanner lamp and exposure glass (you have to reassembled it). If you can print then your USB port is ok(usb cable works), look for scanner software. Sometimes interface cable of the scanner lamp is damaged and needs replacement. Find a tech support for help
pifonski
Feb 23, 2011 | Canon MF3110 All-In-One Laser Printer
I recently changed my os from win vista to win 7pro. when i tried to install my drivers from original disc supplied with my mf3110 it told me it was not compatible. i had no problems with vista!
even though there is no driver for Windows 7 64bit for the Canon MF3110 Multifunction Printer. The solution is to download the Windows 7 64 bit printer drivers for the Canon MF5750 and then install the drivers as your LPT1: Printer. Note this same work around should work in theory with the Canon MF3111 model as well.You know you have the right file because if you go to Canon's website link here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=11148
Select Windows 7 (x64) in the drop down
And download these drivers:
MF5730_5750_MFDrivers_Win_x64_us_EN_7.exe
Install a new Printer and Select these drivers. Set it as the LPT1: port.
Then plug in your MF3110 USB printer and when it looks for drivers "say Have Disk"
Select the drivers for the MF5750 and it should work for you.
I was able to get this configuration working and printed some test pages without issue.
Dec 01, 2010 | Canon MF3110 All-In-One Laser Printer
Has a driver been released for the Canon MF 3110 for Windows 7 as yet? As far as I can see the available drivers go as far as Vista. Cheers TMH
Canon does have a driver for it in the 32 bit format.
Go to MF3110 Downloads
Select the operating system from the drop-down menu.
The driver is listed as MF3110_MFDrivers_Win_x32_us_EN_7.exe
This is actually the same driver for Win 2000, XP, and Vista.
Thanks for using Fixya.
Feb 02, 2010 | Canon ImageClass MF3110 All-In-One Printer
No 64 bit drivers for MF3110
Get MF5700 drivers for vista 64 bit, your MF3110 will work fine with it for printing, although i am still having problem with the scanner.
Jun 25, 2009 | Canon MF3110 All-In-One Laser Printer
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
CD for cannon MF3110
The lastest XP driver is HERE
The latest VISTA driver is HERE
***WARNING***
the info BELOW is from the AUSTRALIAN web site so you may want to check your LOCAL canon site for a different version firmware update
There is a firmware update available that may resolve your issues.
There is also MF3110 User Software v2.01 for download
Go HERE,
Ensure you read and follow the Firmware instructions in the PDF
download and run the firmware update program.
Jul 08, 2008 | Canon MF3110 All-In-One Laser Printer
Canon MF3110 All-In-One Laser Printer Logo
73 people viewed this question
old marine
old marine
