Question about Fujitsu Halcyon ASU9RMLQ Mini Split Wall Mounted Heat Pump Indoor Unit - 9,00
My Fujitsu mini split is flashing both operation n timer lights five times then timer flashes once what is the problem?
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
hvac1960
  • 2133 Answers
SOURCE: Futitsu Inverter Air-con {ASTA09LCC}- Fan operates
To cancel the timer, press timer on setting until it comes 00.00. Or remove batteries from remote and re fix after few minutes. If still problem persists, check and rectify error code of e-5 as follows:
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Hope helpful.
Posted on Jan 09, 2011
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Fujitsu ASU9RLQ
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu Halcyon ASU9RMLQ Mini Split Wall Mounted Heat Pump Indoor Unit - 9,00 Logo
65 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
