Change batteries on altech thermostat - Heating & Cooling
I need User Manual for Altech ALTHC004
Try Googling (Altech)(ALTHC004)(manual) without parens.
Apr 28, 2017 | Computers & Internet
How do I turn on my altech radiator heating controller
When winter comes, and you really need it, the instructions are probably in the manual.
Oct 13, 2016 | Duracell Cameras
What does it mean when the battery error message stay on.replaced batteries, should. I purchase a new thermostat
No friend,
Inside the Honeywell box WILL be a battery. which is there to keep your settings if a Power Failure occurs.
All you have to do is change it and reset your Control.
A typical change of battery is explained here.
http://homeguides.sfgate.com/change-wall-thermostat-battery-25307.html
Sep 13, 2014 | Honeywell Programmable Thermostat Heater
Altech althc014 thermostat
you have 2 possibility
1maybe the batery is dead and the remote doesn-t work
2maybe the contacts of the battery is not perfect(oxidate contacts)
Jan 05, 2014 | Heating & Cooling
Altech thermostat rf
In order to heat whatever medium it heats. Example, if the system is hot water, that hot water will cool below the boiler's internal thermostat set point after it's circulated throughout the house and returns to the boiler. To continue maintaining the preset internal temperature of the water, the boiler has to come on. This is normal operation, nothing to worry about.
Nov 13, 2013 | Heating & Cooling
My set top box Altech PVR 6600 is telling me my HDD is full. It isn't. Also telling me I have no recorded programs I do.
For some problems like these the first thing you should do I actually not reset channels or turn on and off but actually pull the main power cord out from the wall for 10 seconds or more and then plug back in and tada it works again ........
Mar 28, 2013 | Televison & Video
Where can i get oprating instructions for altech model, alth c004 thermostat control fitted to my boiler
hi sorry this isn't a solution, just moved into a new house & i have the same thermostat, just wondering if you found where to get a manual from please? or if you could tell me how to simply turn the heating on & off instead of faffing about with all the silly buttons & settings lol, thanks alot,
Casey :)
Jan 04, 2012 | Heating & Cooling
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
I need user instructions for Altech ALTHC014 digitol thermostat
Here you go, this is pretty much identical to the Altech unit you're describing (Salus RT500RF Manual (SALR503) 531ESALR50310A95), I have the Altech ALTHC014 too, I have checked them against each other. Hope this helps, this is probably why you can't find the Altech manual, as the Salus one is the same and they haven't bothered rebranding this manual to Altech.
Dec 03, 2010 | Heating & Cooling
Heating & Cooling Logo
307 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
