Question about DSC GESTETNER - DSc38u Color Printer
Reset DSc38u black toner chip - DSC GESTETNER - DSc38u Color Printer
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Nov 18, 2015 | Ricoh Aficio Sp C222dn Color Laser Printer...
How do i inset the reset chip for black toner?
buy a new cartrade of ur printer.. or maybe the toner of ur printer check the toner.. try to cleaning the contact of the chip.
Aug 18, 2014 | Xerox Phaser 7760 Laser Printer
New Black Toner installed and not recognised
1.Wrong ink chip
2.Refilled with incorrect toner powder
3.Refilled but toner chip not reset
Jul 10, 2014 | Sharp MX-2300N Color Copier
How to reset CANON LBP 5050 COLOR printer for cartridge chip problem
after more then 400 pages prints i got toner empty message. i refilled black toner but i didnt get clear print out and error messages occured.i gave catridge to reset chip.but they said it cant reset and gave me new chip.but when also i didnt gets clarity prints, some pages has less clear and other very ugly.pls suggest solution.is it cant reset the chip of canon lbp5050
Nov 25, 2010 | Canon Office Equipment & Supplies
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
Thank you for contacting FixYa with your printer inquiry.
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
Hope this helps. Please keep us updated and remember to rate this answer.
May 19, 2010 | HP LaserJet P4015N Printer
Refilled a Lexmark c910 black toner cartridge. Still reads low or empty. Any way to override chip signal to printer so it still prints.
Yes you understand, it is problem Toner chip.When finished your toner then it chip has been disable.It is a technical policy.If you can refill it and again use.You must be reset the chip.Help www.chip resetter.com
Dec 06, 2009 | Lexmark C910 Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
24 people viewed this question
Top DSC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DSC Office Equipment and Supply Expert? Answer questions, earn points and help others
