Question about Whirlpool GHW9400 Front Load Washer
Error Message I have a Whirlpool Washer Model # GWH9400PL4. I keep getting an error message F H shortly after the wash cycle starts. I've check all hoses, the water is running ..and it still happens. HELP!
  • LaundryQueen Oct 12, 2007
    I checked everything as suggested..but I continue to get the error message. I called to have the machine serviced. I'll let you know what they came up with!
    Thanks Again
  • LaundryQueen Oct 16, 2007
    Jim,
    You were right. THe service guy came out and did a series of test (pushing buttons) and it was the flow meter. I have a warranty so it didn't cost me a dime. I can now get my laundry done..my son is heading off to Sweden..he can now leave the country with CLEAN CLOTHES!
    THanks Again!
    Problem Solver:
  • 15 Answers
Take the bottom panel of the machine.three torx screws hidden on the bottom hold it in place inside the machine in a plastic envople the should be a service manual. Find what the code for your machine indicates. Your code i think means a filling problem if this is true check the screens in the hoses or in the fill valve they maybe clogged. Also there is a flow meter in the water inlet hose that may need replacing. But let me know
Posted on Oct 10, 2007
My washer keeps flashing f24 and wont turn on what does it mean?
Hello, This is a water tempreture sensor error due to if the tempreture sensor value is out of range during the water heating up step during the cycle. Unplug washer or disconnect power, Check the water tempreture sensor and connection to it,check the resistance of the heating element using a multimeter. If you have any further questions message me back this error code diagnosis is for a whirlpool duet washer if you happen to have a different type of washing machine message me back your make and model number of your machine. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 18, 2011 | Whirlpool Washing Machines
I keep getting an F1 error code on my whirlpool elite washer at beginning of cycle and at beginning of rinse cycle, why?
F1 error code usually refers to a control board or touch pad failure in a whirlpool washer.
Hope this helps if you have any further questions message me back Thanks Rick
Jul 17, 2011 | Washing Machines
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Error message F 11
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential causes: • Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) (its the
usual thing)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component. Check for sharp edges in wash basket of machine. Companies want you to dump your machine & go for a new one, keeps their factories running.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
57 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
