Question about Frigidaire Refrigerators
Frigidaire refrigerator wiring diagram for the im115 ice maker
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Posted on Nov 19, 2007
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
richroth
  • 9472 Answers
SOURCE: My Frigidaire Side by Side Refrigerator model #FFHS2311LBO ice maker makes a loud popping sound
Does it pop before it dumps the ice?
Posted on Dec 01, 2012
What size water filter should be used for this ice maker Frigidaire IM115?
Thank you for your post, friend!
Based off the information you have provided you need to know what size water filter needs to be used for a IM115 inside of a Frigidaire refrigerator. Typically, the IM115 needs an in line water filter and that would be attached on the line. If you need additional information on that part I would recommend contacting the manufacturer for assistance. Hopefully this is helpful. -Matt
Feb 12, 2015 | Frigidaire Refrigerators
Stop ice making
I appreciate your post, friend!
Based off the information you are providing about your icemaker, IM115. It may need to be exchanged out normally if a part goes out within that model there is not a replacement part available. You may want to consult a professional technician for proper diagnosis and repair because it is possible that the icemaker is faulty or the water valve is not receiving signals to shut off. I hope this is helpful. -Matt
Oct 13, 2014 | Frigidaire Im115 Im115 Ice Maker Kit
My IM115 frigedaire ice maker, doesn't seem to be making ice fast enough
The key to ice production is temperature, so if the unit is running at "0" the fan also has to run to cool faster. That a good look at these items and see where the issue may be. In this environment point blank information is the only way anyone could assist you. Lack of information causes no response or incomplete answers. Check the temperatures also check the ice maker for pealing or flaking mold issues. Good luck
Aug 25, 2014 | Frigidaire Im115 Im115 Ice Maker Kit
Water is ot coming thru to icemaker
On back side the fridge water line freeze
Jul 12, 2014 | Frigidaire Im115 Im115 Ice Maker Kit
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
FRS20WRHW5 is dripping condensation from water ice cube dispenser area. Replaced heater, no help. Wiring diagram would be useful.....
Wiring diagrams are usually located under the kickplate, in the control console in the refrigerator, or in the compressor area.  The icemaker is all self controlled.  It has a power, a neutral, a power coming from the valve and a, ground.  If the heater for the ice maker is staying on you will have to replace the whole unit.  Based on where you say your water is coming from, I would say the flapper door for the ice maker either is not sealing or not closing.  The seal is the most common cause
Oct 25, 2009 | Frigidaire Refrigerators
Frigidaire Gallery Model GS26HSZBB2 ice maker doesn't fill up
Hello.
It is time to replace your icemaker. The best place I have found to get them is at Lowes. They are above 100 dollars everywhere else but they are 49.99 at Lowes. The part number is IM115. Just let the guy in appliances know you need an icemaker for a Frigidaire unit.
Jul 22, 2009 | Refrigerators
Nov 19, 2007 | Refrigerators
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
