Question about Royal Satellite 40 Typewriter
How do i install correction ribon on a royal typewriter
3 Suggested Answers
  • 92 Answers
SOURCE: My adler-royal typewriter doesn't type the correct
bad logic
Posted on Aug 29, 2009
unaasp192
  • 29 Answers
SOURCE: I have an old Royal 501Plus typewriter.
check if typing wheel is the correct one for this machine.
you have to make sure the bright side of he correction has to face you
unaasp192
Posted on Apr 12, 2010
Royal 501 electronic typewriter repair
iF IT HAS A LANG (LANGUAGE KEY) try it in another lang
Oct 18, 2016 | Royal Office Equipment & Supplies
Ribon will not advance
Look for debris in the carrier movement area. Then try a shot of WD40 on the silver shafts that the carrier slides on.
DickyO
Jan 14, 2013 | Royal TA Adler-Satellite 40 Electric...
I have an old Royal 501Plus typewriter. Correction tape will not correct. I took typing wheel out and will not type correct letters now. Please help!
unaasp192
Apr 01, 2010 | Royal PowerWriter Typewriter
Smith Corona PWP 4002 fails to type,. need to know if ribbon is correctly installed as well as circular disk. Thanks
Did you buy an OEM or COMPATIBLE ribbon? If you bought a compatible, please make sure you have bought the correct design for your typewriter. Some compatible ribbons come with a lug that prevents them from sitting correctly.
I note that you posted this problem over a month ago. If you haven't solved the problem by now, i would advise you to contact www.inkribbonpaper.co.uk. I have used them a number of times with great success for our smith corona, brother and royal typewriters
Nov 23, 2009 | Smith Corona Office Equipment & Supplies
I have an Royal-Adler Satellite 40 which is mistyping. We tried resetting the wheel, but that didn't work. Does anyone know the codes to "clear" codes that may have accidentally been entered into the...
Take the printwheel out and look for bent or broken spokes, check the P/W area for debris. be sure that you have a dry correction tape the tacky ones will gige you fits.
DickyO
Aug 04, 2009 | Royal Satellite 40 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
Royal Satellite II
Make sure the printwheel is in correctly. Also the top cover switch. Make sure it is working. Lawrence
Mar 17, 2008 | Royal Satellite 40 Typewriter
Royal Satellite 40 Typewriter Logo
64 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
