Question about Hobart P660 Stand Mixer
When turning on my Hobart p660 mixer it makes a loud noise that is continuous and sometimes blows the circuit breaker.
  • 20 Answers
SOURCE: Hobart L800 making noise
If you can send me your email address i can send you a parts catalog for your L800 They have no way to send a link here is my email address
onesharpstore@comcast.net
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: Hobart D300T Mixer Loud Buzzing and No Spinning
You may have a wire not fully seated in your plug, or the worm gear you've just replaced is bound by something ( a gear tooth?) or wrong worm gear. Check to see if all the gears are seated properly. You should be able to turn the agitator by hand. If not, something is jammed in the gears. The other possibility is the windings in the armature are bad.
Posted on Aug 06, 2009
bigg t
  • 640 Answers
SOURCE: hi i have hobart mixer 220v and it start to make
What is the model and ml # on the data plate?I'm a hobart tech and repair these mixers often,let me know.
Posted on Nov 22, 2009
  • 110 Answers
SOURCE: need a wire diagram for a hobart p660 mixer
the elec. schamatic for the p-660 should be inside the top cover of the mixer, that mixer was specifically built for s'barros pizzerias
Posted on Jan 10, 2010
justinbur167
  • 257 Answers
SOURCE: I have a Hobart P660
Hello Pizzaangel,
It sounds like you are having a problem with you Hobart P660, everytime you run it trips the breaker. Sounds like the switch is shorting out. You need to replace the switch and that should solve the problem that you are having.
Posted on Mar 06, 2011
Hobart P660 keeps shutting off and tripping the breaker
Sounds like the cable is too small. If you're hooking it up to 15 amp breaker you need the correct diameter size extension cord, and the equipment cannot be rated more than 15 amp or you'll have a problem. I perceive this may be the solution based on the fact that you said that the motor was not coming up to speed.
Jan 07, 2014 | Hobart P660 Stand Mixer
The hopper in my p660 to shred cheese is operating backwards
the whole mixer is running backwards, change any two wires on the 3 phase power going into mixer.
Nov 23, 2011 | Hobart P660 Stand Mixer
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
I have a Hobart P660 stand mixer. It turns on for a moment then trips the breaker. Would this be a "relay" or "switch" problem?
Hello Pizzaangel,
Feb 15, 2011 | Hobart P660 Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Need a wire diagram for a hobart p660 mixer
Sep 03, 2009 | Hobart P660 Stand Mixer
Mar 10, 2009 | Hobart D300 Stand Mixer
Moving a p660 mixer
I personally would not do it.
Dec 27, 2008 | Hobart P660 Stand Mixer
Hobart P660 Stand Mixer Logo
41 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
