Question about Hobart P660 Stand Mixer
When turning on my p660 mixer it makes a loud noise that is continuous and sometimes blows the circuit breaker.
4 Suggested Answers
  • 68 Answers
SOURCE: Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Posted on Jun 21, 2008
justinbur167
  • 257 Answers
SOURCE: I have a Hobart P660
Hello Pizzaangel,
It sounds like you are having a problem with you Hobart P660, everytime you run it trips the breaker. Sounds like the switch is shorting out. You need to replace the switch and that should solve the problem that you are having.
Posted on Mar 06, 2011
SOURCE: moving a p660 mixer
Use a appliance dolly strapped on the back.with a few people feeling orders no problem
Posted on Apr 05, 2012
Hobart P660 keeps shutting off and tripping the breaker
Sounds like the cable is too small. If you're hooking it up to 15 amp breaker you need the correct diameter size extension cord, and the equipment cannot be rated more than 15 amp or you'll have a problem. I perceive this may be the solution based on the fact that you said that the motor was not coming up to speed.
Jan 07, 2014 | Hobart P660 Stand Mixer
The hopper in my p660 to shred cheese is operating backwards
the whole mixer is running backwards, change any two wires on the 3 phase power going into mixer.
Nov 23, 2011 | Hobart P660 Stand Mixer
I have a Hobart P660 stand mixer. It turns on for a moment then trips the breaker. Would this be a "relay" or "switch" problem?
Hello Pizzaangel,
Feb 15, 2011 | Hobart P660 Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Making noise in planetary gear area. we have a l 800 hobart mixer just purchased ,has wirring noise planetary gear area ,i 'm quite sure it is common wear from use , but want to repair...
The noise you are describing sounds like the noise associated with the pinion gear meshing with the ring gear in the planetary. Depending on the age of the unit, some noise is to be expected. The lubricant used in the planetary is different than that of the main transmission and is not visible without disassembly. Again, depending on age of the mixer, your planetary may have a small amount of oil and a pump to bathe the gears or just a generous amount of grease applied to the gears. The only way to properly inspect the planetary is to remove it. Depending on your luck, this may be 20 min job or several hours. It all depends on the ease of which the planetary releases from the main center shaft. Should you decide to tackle this job yourself let me know and we'll do our best to assist you. Several knowlegeable techs monitor this area of the site.
Sep 13, 2009 | Hobart P660 Stand Mixer
Need a wire diagram for a hobart p660 mixer
the elec. schamatic for the p-660 should be inside the top cover of the mixer, that mixer was specifically built for s'barros pizzerias
Sep 03, 2009 | Hobart P660 Stand Mixer
Hobart D300T Mixer Loud Buzzing and No Spinning
You may have a wire not fully seated in your plug, or the worm gear you've just replaced is bound by something ( a gear tooth?) or wrong worm gear. Check to see if all the gears are seated properly. You should be able to turn the agitator by hand. If not, something is jammed in the gears. The other possibility is the windings in the armature are bad.
Mar 10, 2009 | Hobart D300 Stand Mixer
Moving a p660 mixer
I personally would not do it.
Dec 27, 2008 | Hobart P660 Stand Mixer
Hobart P660 Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
