Question about Refrigerators
My kitchenaid model kbfs22ewms3 is leaking water at the left back corner of the freezer and collecting on the bottom and freezing. I don't see a drain for the freezer so where is the water coming from?
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
Water collecting inside refrigerator
At the back is a little channel with a hole in that drains to the outside of the fridge. Remove the drawers and shelf and blow through the hole with a drinking straw.
Jun 13, 2012 | General Electric Refrigerators
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
Water is leaking inside the freezer and collecting at the bottom of the freezer. It eventually freezes down at the bottom of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpful please rate me.
Don't forget to check the icemaker for leakage, also
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2011 | Kenmore Side by Side Refrigerator
My freezer on the french door model is freezing over. All of my food has what appears to be snow. Why
warm air is somehow leaking into the freezer or a common problem with bottom mount doors is they get left open and that's what happens,check the gasket or the door was left open.
Apr 11, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water collecting in the bottom of freezer.
There's a small drain in the bottom of the freezer compartment. It will clog up from time to time and cause water to pool up, then run wherever it can. So, find that little drain (small hole about the size of a dime or so) and un-clog it. you can do this with hot water and a turkey baster!
Aug 30, 2009 | KitchenAid 25.4 cu. ft. Side-By-Side...
Water leaking from the left lower corner of the freezer
there is a drain at the bottom of the evaporator in the freezer section which is blocked,pour some hot water into the drain and that may unblock it
Jun 07, 2009 | Frigidaire FRS26ZSG
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
