I have this Sony KDL-46HX729 that will blink a red light 5 times then stop and blink 5 times again and keep going.
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: plasma tv th-42pd50u not come
The light blinking twice means there is a fault within the system and it is a code to tell Panasonic where roughly the fault lies.
Go to Panasonic's web site and look for your set then input the fault code and hopefully they will tell you where the fault lies.
SOURCE: Sony KDL-32V2500 : It comes on and after few
This is sort of a generic answer but I found this info about Sony blink codes. Hope it helps!
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on the
A board. In addition, unit could be in IK blanking, try turning up
screen slightly.
