Question about Water Heaters
Rheem PVW50-36FV Owners manual
Rheem gas furnace displayes 3 blinks, does not ignite.....3 blinks means???
Look inside the unit, the codes are usually on or near the schematic of the unit. Otherwise check the owners manual.
Feb 16, 2015 | Rheem Water Heaters
TANKLESS WATER HEATER WILL NOT STAY ON
Copy following link for troubleshoot resources, and possible manual for Rheem, Richmond, Paloma water heaters:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 16, 2012 | Water Heaters
No hot water.Error code:C2 11 (Rheem GT 199-PVN-2)
Resourceful do-it-yourselfer will find following links valuable
1) C11 is 'no ignition'
Check following link for Paloma error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
2) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
3) Typical Rheem manuals
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
http://waterheatertimer.org/pdf/RHRheem-Hvy-Dty-IndoorOutdoor.pdf
http://waterheatertimer.org/pdf/Tankless_Condensing_AP15896.pdf
4) Rheem site where you can find and download your manual if it shows
http://www.rheem.com/hrc.aspx
5) Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
6) Contact Rheem
http://www.rheem.com/Contact.aspx
7) Search Fixya for Rheem questions and answers
http://www.fixya.com/tags/rtg_74pvn
8) Post question on pro water heater forum: This is where I go to catch up on always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
9) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
10) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem GT-199PVN Heavy Duty Indoor Natural...
My Richmond tankless water heater is flashing the error code 76 and C8
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
Contact Rheem: they will usually kick you back to local service technician.
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
Pay for answer at fixya:
Mar 17, 2011 | Rheem Tankless Hot Water Heater...
How can I get an owners manual for a Richmond's tankless hot water heater? Allso the instructions to install. Model # RMTGL74PVN Serial # RMLN0109JO1242 Thank you, Mark
Try this link.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1298033256538/pdf/ownersmanuals/rheem/RTG74IndoorOutdoor_owners.pdf
Feb 18, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Can i convert a rheem40 gallon naturalgas over to propane by changing the orfis
Normally owners manual would give specs, as well as proper procedure or other orifice to perform conversion. Check owners package, or near burner or on back somewhere for small package with info and possible orifice and instructions.
Have a look at this link, for details, and contacts for information.
http://canada.rheem.com/content/resources/documents/specsheets/Canada/ResProd/ResGas/CAN_ResPROGuardianGas.pdf
Nov 03, 2010 | Rheem Water Heaters
What does code c4 and c12 mean
Contact Paloma/Rheem customer (800-432-8373) or refer to your owners manual troubleshooting guide.
Nov 17, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
111 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
