I am having the same proble too..I am going to open it up and see if I can fix it, I'll keep u guys posted...
Blazemorefire..
I just encountered the same exact problem. The LED light stays on, no matter what, it's not in pairing mode, it then runs its battery down and dies, and cannot be used at all.
This thing is going in the garbage. What a waste of money. Motorola prides itself on quality, but should be ashamed of themselves for this (oh - and has anyone had as much fun with the charger for this thing??)
Same problem with mine...
there is no solution for that, I've had the same problem a year ago... and it's a useless unit... there's no solution and there are a lot of Hs820 with this problem....
This headset is a piece of sh** !!
Same problem with my headset cannot turn it off and it is on all the time.. Cannot shut it off..
same problem. The light goes out after it has been charging, but when I unplug it the light comes back on and won't turn off. The headset is useless and won't work...help!!!
I plugged my Motorola HS820 into Charge overnight and when i disconnected the charger the light stays on and i cant get my headset to switch on or off or pair with my mobile! Is there a reset button or something i can do?
ok waht can i do broke it i brought it from a year help pleaseeeeeeeeeeeeee
Same,same,same
I have had this happen twice now. It's a great unit but after the second one I got did the same thing I think I'll avoid a third. Only solution is to get Motorola to repair or replace it, but good luck on getting that to happen.
