Question about Samsung DA31-00146E - Evaporator Fan Motor without Fan
How do i take the fan off my evaporator fan motor on samsung
3 Suggested Answers
SOURCE: Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
walterkunesk
  • 683 Answers
SOURCE: samsung rm255lash, evaporator fan motor
i quick fix would be to take a quart of oil and remove the fan motor and soak it in the oil. This wont hurt it anter a couple of min in the oil, hang up so that all the oil can drain off it, then wipe it down. install motor and try again, let me know.
Posted on Feb 21, 2011
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like someone will need to examine the fan motor and test the voltage to the fans inside and outside the refrigerator. You will need to have this done to eliminate what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
9_16_2012_3_30_31_pm.jpgDA31-00103A
Sep 14, 2012 | Samsung RS2630WW Side by Side Refrigerator
Samsung rm255lash, evaporator fan motor on refrigerator side making loud noise. We took off the panels as best we could but it seemed like it was frozen on. When I open the fridge and hold down the light...
Feb 21, 2011 | Samsung RM255LASH Side by Side...
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
May 12, 2009 | Samsung Refrigerators
Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Apr 28, 2009 | Kenmore Refrigerators
Samsung AW1003M Air Conditioner how to clean Fan inside??
hello! there well, there are two fan coupled together on a/c the condenser fan and blower fan,if this is split type the fan and blower are separated.the procedure is the same way.doing this release lock off and take off front cover then pull out ac unit assembly,after pull out,open terminal control box disconnected all wiring connected on compressor motor and fan motor, loosen all stud bolt on compressor blower fan case.this well exposed fan and blower w/ the motor.cover the motor of plastic sheet then, pressurize water wiil use to clean blower fan observed the motor not to wet by water if this wet don't try to run let it dry off or else this wii burn out so take all necessary precaution, beside mosly cleaning procedure includes the fin tube of condenser and evaporator there are foriegn particles and moisture emerged in evaporator mostly that why insufficient cooling effect on condenser heat rejection also affected if dirty fin tube emerged,.theres is lye detergent use and mix to water pour this to evaporator and condenser fin tube wait for 15 to 30 min soaking to rinse dirt will come out to fin.observed not to distorted fin of tube on eveaporator and condenser.,then pressurise this by water again if cleaning was done dry it off until all dirt disappear.if finishe put back all casing of compressor,evaporator and condenser, then connect all electrical control connection on circuit board, double check connection just put back what ever disconnected parts dont try to alter specially electrical control connection on circuit board.this is a hard task and risky if yout not qualified to handle this job bring it or call a service technician.have a nice and cool day regards and thank's.
Mar 29, 2009 | Samsung AW1003M Air Conditioner
Hello, I have a side-by-side Samsung Refrig from Costco. I freezer started to ice up today. I removed the ice maker compartment and took some of hte freezer items out to provide more room for the air to...
the evaporator fan motor will not run when you have the door open - you have to press the door switch in to make it run.
But if you are doing this and the fan is still not running then this explains the evaporator ice up problem.
You will have to take it apart (make sure that the power is off) and just unplug the evap fan (usually just plugged in)
Usually these fans are a standard type of fan and you will be able to get one from a electical wholesaler or just call samsung and get one from them - make sure you have the model number with you when you order it though.
Apr 09, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Samsung DA31-00146E - Evaporator Fan Motor without Fan Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
