Question about Magnavox Mdr537h Blk Dvd Hdd Recorder With Digital Tuner
Dvd tray on MDR537H will not open
Upon initial set-up, the DVD tray drawer will not open. Everything seems to setup okay and you can hear a clicking sound and you can see the "OPEN"on the window but it doesn't open. I tried the unplug-push power button 6 times-didn't work. tried unplug- press open button 10 times-didn't work. so ????
    Problem Solver:
  • 6 Answers
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Posted on Nov 28, 2014
3 Suggested Answers
kalamazoo222
  • 285 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Posted on Mar 05, 2011
ercupa190
  • 12223 Answers
SOURCE: magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Posted on Sep 27, 2012
Testimonial: "I took it apart, I really didn't do anything other than blow some air into it and used some alcohol with cotton swab on a few of the parts, put together and its works, I can't say I did anything other than having it apart, unplugging & plugging back in to test the door, I think one of those plastic wheels I cleaned with alcohol may have fixed it, can't say for sure."
How do I insert a DVD in to my Evesham novatech computer, serial no. WO00966604?
CD s and DVD s have a tray that slides out of the computer. When you get the tray open place the disk (writing if any usually on the top) in the tray, and gently press it down so that it is held by the deice in the middle. Either the tray will withdraw itself into the machine after about 10s or gently pushing it towards the machine from the front will cause the tray to enter the machine.
Press the windows button and with your mouse click on My Computer click on the CD or DVD item and the file might open ...
To open the CD/DVD tray or drawer either press gently on the front or press the little button on the front, or else go to My Computer (above) righ click on either the CD r DVD icon and then left click on open or eject on the drop down menu that should appear
19.December.2014
May 27, 2014 | Evesham Computers & Internet
The disc drawer will not open. How can I get it
There will be a small hole in the front tray of the DVD, use a straightened paper clip, or similar stiff wire, & push it into the hole and gently push in, until you hear/feel a "Click" gently keep pushing 7 it should now come open,
Feb 17, 2010 | Memorex MVD2042 DVD Player
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd tray will not open
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
May 12, 2009 | Televison & Video
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
DVD Drawer won't open-- paperclip method isn't working
Unplug it. You'll have to open the cover. Then you may have to remove the tray assembly from the frame. On the bottom you will be able to access the belt. If you're luck, it might be in another location on top or off to the side.
Apr 25, 2008 | GoVideo VR2940 DVD Recorder/VCR
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
No response from dvd following pushing drawer shut
You have likely broken the timing of the dvd mechanism, especially if you heard any clicking sounds when you 'pushed it shut'. Everything from the tray to the traverse deck that holds the optical pickup is ran on a system of gears that if forced is easily broken. Don't even attempt to take it apart as even a pro would struggle to re-time a disassembled mech! I reccomend you take it to a repair shop for an estimate.
Aug 30, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Magnavox Mdr537h Blk Dvd Hdd Recorder With Digital Tuner Logo
176 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
