Question about Home
Best replacement flapper for a vortens vienna
Flapper leaks
this is a case that dictates you replace the flapper.
Mar 06, 2011 | Eljer 141-0220-00 Toilet Tank White
K4608 toilet. Ingenium flush valve. Constant feint leak into bowl. Not running into overflow. I'm Guessing needs new flapper. Agree?
Yes. If it still leaks after replacing the flapper then you may need to replace the entire flush valve but that is very rare.
Fluid master in my opinion makes the best most reliable replacement flappers or you can go with the OEM parts.
Mar 05, 2011 | Kohler Home
My K3489 toilet leaks down and refills every few minutes. I replaced the flapper with a factory replacement with no affect. The leak seems to be around the 83996 soft rubber gasket at the bottom of the...
Hello, W/D here.
With the water off, drain the tank (lift the flapper). Look inside where the flapper seats. If the (usually black) gasket is rippled, this may be the cause of your trouble. You can remove the rippled portion of the gasket with a razor knife, just be very careful not to damage the flapper seat. Removing the protruding material will allow the flapper to fully seat without damaging the gasket integrity.
Best regards,
--W/D--
Jan 17, 2011 | Kohler Home
Our toilet will not hold water in the bowl?
it is time to replace the flapper. turn water off, remove old flapper, wipe port off with rag where flapper seals, adjust chain to same length as old flapper, install new flapper. fluidmaster is the best brand.
Dec 05, 2010 | Home
Toto i piece toilet 6 ltr. water leaking to lower bowl replaced flapper, tightened tank drain works fine for a short period. Should I be purchasing a manufacting flapper Tom C
Yes, for many toilets you need to get the exact flapper to make them seal properly...the generic will often not work properly..
heatman101
Aug 04, 2010 | Toto UltraMax One Piece Toilet, 1.6 GPF -...
American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Sep 26, 2009 | Home
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Where could I find the flapper for Sterling 1.6GPF toilet?
Here's the easiest way: Close the water valve that supplies water to the toilet. Lift the lid off of the tank. If you look in from the top, you'll see a long white tube in the middle of the tank running from the top to the bottom. It is called the overflow tube. At the base of the tube is the flapper, and it anchors to the base of the tube, and is actuated by the handle on the front of the tank pulling the chain connected to the flapper. Flush the tiolet, and you'll see what I'm talking about. To replace the flapper, you'll need a replacement. Remove your flapper and get a pretty good look at it. You can buy a replacement at any hardware store. A 'universal' replacement should fit, but take the old one with you to be sure. When you look at the new flappers, you'll notice a rubber ring attached to the flapper, and you may not have one on yout toilet. No worrys here, the ring can be cut out if yours is of the type that just clips onto two lugs at the base of the overflow tube. Install your flapper, hook up the chain and turn the water back on.
The chain should have just a little slack in it.
Best regards, --W/D-- please feel free to rate this solution....Thanx!
Aug 02, 2009 | Sterling 402315-96 Biscuit Windham...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Home Logo
56 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
