Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
My WD25001032-001 is on, but it will not connect to the pc (not showing in Explorer either).
When connecting the power cable, it makes a clicking sound - which I guess is the harddisk.
  • 82 Answers
The clicking noise is a mechanical failure caused by the read/write arm making contact with the spinning disk or catching on something it shouldn't.
Check the warranty status at:WD Support Warranty RMA Services
If the drive is out of warranty, and you have important data on the drive, and you can't afford to send it to a company to retrieve your files and have tried absolutely everything to get get it off, you can try this: Put the drive (and silicon packs in there if available to absorb moisture) in an air-tight ziplock bag. Place it in the freezer wrapped in a towel for a few hours. (Chilling the drive makes the metal inside the drive contract enough for the arm to function properly)
Remove from the freezer and immediately attach to the computer. If detected, transfer files immediately. The drive will heat up quickly and the mechanical failure will return.
Posted on Apr 27, 2014
3 Suggested Answers
  • 81 Answers
SOURCE: My WD external does not connect well to my laptop.
sounds like the drive heads are broken or out of line the unit you have does require a power cord its the data cord that it doesn't need , suggestion is to remove the driver heads and replace them with new ones from a matching Drive , its all you can do to save your vital files , if you are willing to replace your heads I can assist you however its not an easy task
Posted on Jan 11, 2010
bronk50
  • 27725 Answers
SOURCE: I own a WD MyBook.
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty/faulty hard drive give your hard drive a firm tap on the side this should free up the reader arm
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead using a multimeter
or
control panel administrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Posted on Dec 04, 2010
With wireless connected, internet explore is not working
Hi, if the wireless is working and the status icon on the bottom right shows connected, speed and signal strength and internet explorer is not working, do the following to make sure if it's problem with internet explorer or wireless connection:
click on start > run > cmd, click ok
type: ipconfig. it should show your ip address. Also type for example: ping www.google.com
if it pings successfully, you have internet connection. Refresh your internet explorer or close it and reopen. Also you may want to log into any instant messenger such as yahoo. I hope this helps
Mar 17, 2011 | Acer Aspire One PC Notebook
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I type the 192.168.0.1 to setup router nothing happens
Have you connected your PC to one of the four LAN ports on the bank of the D-Link using an Ethernet cable?
If so, open a command prompt on your PC and type in IPCONFIG, then confirm that the details for Local Area Connection show a Default Gateway of 192.168.0.1.
If there is no Default Gateway, or it shows a different value, your ethernet connection may have been manually configured: visit Control Panel -> Network Settings and double-click on Local Area Connection, then TCP/IP settings and make sure everything is set to default.
Also check your Internet Explorer Tools Menu -> Internet Options -> Connections -> LAN Settings and make sure you don't have any proxy servers turned on.
Nov 06, 2010 | D-Link AirPlus DI-524 Wireless Router
CONNECTED TO WINDOWS XP PC BUT NOT SHOWING IN WINDOWS EXPLORER. IF I TRY TO VIEW CD OR DVD I CANNOT FIND THE DVD ICON ON THE PC AT REMOVABLE DEVICES
make sure that the IDE/SATA Cale that you are usin is workin properly and also make sure that the power cable from the powersupply is workin..while restartin you can press the eject button to see if there will be a Green liht to check if there is a power on the DVD..
3 thinGs to check:
*sata/ide cable
*Power cable from the PSU
*DVD writer if all cables are workin try to connect the dvd writer to a diff computer to check if it is faulty
Jul 24, 2010 | Samsung SpeedPlus DVD-Writer 20x, Black ...
How can i get itunes to download on my phillips gogear 4gb?
Transfer music via Windows Media Player 10:
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
From PC to Laptop
Reboot the modem (unplug power, replug) each time you switch from one to the other. Make sure the "Local Area Connection" is enabled on the laptop and the Yellow activity light on the bottom should blink steadily.
Mar 13, 2009 | Arris SURFboard SB5120 Modem
Trying to connect between cable pc xp edition and new dell vista laptop
the SSID is only the name which your connection is called.
If you have security enabled, you will need to type in the passkey when asked.
First go to internet explorer open it and go to tools>connections tab, then tick 'never dial a connection' and close I. Explorer.
go to control panel>network connections>right click on your wireless connection icon, then go to the TCP/IP line, highlight it, click properties, then select 'Obtain IP address automatically.
Select Ok, then close window, go to internet explorer, then open it up and you may need to click refresh a few times ,but should connect
Aug 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cd and dvd no longer shows on my computer or windows explorer
Hi soren,
Open up your pc, and remove the cables connected to your cdrom, power on your pc, then shut it down again, connect back all the cables into your cdrom and see if it works.
if you have an extra cdrom, try it out, you might have a faulty cdrom there, or maybe somethings wrong with your IDE cable(if your using that) or your sata cable.
Jun 21, 2008 | Toshiba Computers & Internet
Internet Explorer
Hi Suz du - try this - on your IE - click on tools>internet options>connections. Make sure that there's nothing in the dial-up box. If there is, remove it. Then click on Lan settings snd make sure automatically detect settings is clicked. Then click ok. Close IE and re-open and try it.
If this fixes your problem PLEASE rate as fixed. If not DON'T RATE YET, Just add a comment letting me know what happened and gladly assist you further. Thanks.
Jeff
May 12, 2008 | Gateway GM5664 Desktop PC
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
134 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
