Question about iLO DVDR05 DVD Recorder
Gateway AR-230 DVD recorder
The disc drawer refuses to open. The problem was intermittent at first but now I can't get the machine to open unless I try to pry the drawer open. It's always been clean and in controlled climate and works well once I manage to get a disc inside. I think the drawer is off a bit cuz sometimes I have to push it shut further in in order for the machine to acknowledge the disc. Is it possible for me to open the machine and see if the drawer is off kilter? Thank you!
  • Anonymous Feb 03, 2008
    door will not open
I have one and all i do is tap the top a few time tap it right where the door is
Posted on Sep 15, 2008
I read about some magnetic thing failing as the unit gets older. Mine does this sometimes and I gently tap top of unit as I hit the eject button. Works on mine so far.
Posted on Aug 27, 2008
After recording a program I go to disc tools and click on finalize and the screen says to change disc and the recorder never finalize the disc.
It will eventually finish. Finalizing can some time take a few hours depending on the speed of the writer and machine itself.
Feb 16, 2010 | Gateway AR-230 DVD Recorder
Disc Tray will not open
My Gateway model #AR-230 tray would not open after several years of use. Removed the black sheet metal cover from the player to access the tray mounting screws in the black plastic tray frame. By tightening or loosening the little screws on both sides of the front of the tray mechanism, I got the tray to slide out (open) reliably again. The problem is the very close tolerance of the internal tray mechanism with the front case opening causes a mechanical hangup or interference. chemicalladdie
Sep 14, 2009 | Gateway AR-230 DVD Recorder
DVD Drawer will not open on my Gateway AR-230 recorder.
look for a small hole on the face of the player,it is for opening the player tray when the button won't.Stick the end of a paperclip into the hole and push in the tray should open.Good Luck.
Sep 07, 2009 | Televison & Video
Ar 230 will not play most recorded disks that played used to pla
My Cyberhome DVD 300 usede to work fine. I rarely used it since I bought it a Wal-Mart less than six months ago. Lost my manual and codes so I don't know how to solve this problem. A red light is showing with a DVD stuck inside the player. Any ideas??
Jul 20, 2009 | Gateway AR-230 DVD Recorder
Gateway AR 230 Recorder recording sound has interference noise
Disconnect the "audio-out" cables from the unit.
Leave the "audio-in" cables connected.
Try to record. Does this work correctly?
Apr 21, 2009 | Gateway AR-230 DVD Recorder
Gateway DVD Recorder AR-230 Disk tray does not open.
Unplug for 2 hours. otherwise timing is off and timing needs to be adjusted or rubber replaced..usually Pro shop or open it up and look aroound , possibly a belt came off ??
Please rate!
rate please!
Mar 16, 2009 | Gateway AR-230 DVD Recorder
My DVD Drawer will not open on my Gateway Laptop
My dvd drawer will not open on my
Gateway Laptop
Nov 29, 2008 | Gateway AR-230 DVD Recorder
Gateway AR 230 DVD Recorder will no recognize any of my dvds
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's. Usually any cheep brand will work.
Dec 03, 2007 | Gateway AR-230 DVD Recorder
Here is the link to the manual if you need it; No remote codes, but: Gateway Technical Support at 800-846-2301, Monday through Friday, from 7:00 a.m. to 9:00 p.m. Central Time. Should be able to help Please post again if you get no joy from them :)
Mar 28, 2007 | Gateway AR-230 DVD Recorder
iLO DVDR05 DVD Recorder Logo
117 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
