Question about Brother MFC 210C All-In-One InkJet Printer
BLACK no longer printing
My printer sat idle for a little while and now, it won't print black. I've tried multiple cleaning cycles and two new cartridges and nothing seems to work. Colors are fine. Any suggestions? Thanks
  • Denis Rouleau Oct 11, 2007
    Thanks for the advice. I didn't solve it but close. Here is what I did to get it to work.
    I didn't have a genuine Brother cartridge so I had to do with my generic.
    I actually opened the printer and watched the power cleaning cycle you pointed me to and noticed that the black piping had air gaps that never went away. After trying several other things, all I needed to do was to put some tape on top of the cartridge were the clip goes to push it down much further. That solved it.
    I'm not sure if the problem was related to the cartridge or the printer or a combination of both but the thing that I got from this is that the cartridge must be held down as far as possible.
    Thanks again for the solution.
    BTW
    a) 09 didn't work for printing the test sheet. I got a couple beeps when I did it.
    b) Where can I get all the maintenance code?
  • 832 Answers
Check if cartridge is in good position by reinserting. Do use a new original brother ink cartridge for that!!! Press menu then start mono (blue button). Then arrow-up button fourtimes. Machine will be in maintenance modus. press 7 then 6 : display will be cleaning_all. Press 3: power_p all. Press start mono. Machine starts power cleaning. After cleaning when maintanance is in display again press 0 (zero) then 9. machine prints test sheet. If its ok press 9 then 9 to leave the maintenance modus. If not do procedur mentioned above. If you dont see any bk the printhead has dryed out and cant be fixed anymore.
Posted on Oct 10, 2007
  • Mix-it-up
    Mix-it-up Oct 12, 2007
    You have a mfc 210c built for the us market with a different firmware. Mfc built for other countries wont have the prob with the maintance printing order by pressing 0 and 9.
    You have to search the internet to collect the maintenance codes. This codes will actually only work for one series of printers (e.g. printers with one of the same ink cartridges) and it depends on country related issues and Mfc builts with different parts inside (for example: thats why you cant print a test sheet and other machines can do. Or  your machine wont work within Europe or Asia though there is a different fax module inside).
SOURCE:
My printer has sat idle for months and now won't print a copy
In dries out, try purchasing new ink cartridge it will probably work just fine.
Sep 14, 2015 | HP PSC 750 All-In-One InkJet Printer
My hp 5510 photosmart printer will not print in black
Make sure you have run a cleaning cycle before spending money replacing anything. Sometimes the print heads will get a little dry and a color or multiple colors will stop printing. Have you replaced the black cartridge recently? Make sure you have pulled all the tape off correctly. There is an air hole that needs to be opened usually under the tape that will prevent the ink from flowing out of the cartridge. Let us know what your results are after checking the cartridge and running a cleaning.
Jul 07, 2014 | Brother HL-2040 Laser Printer
Brother mfc-6490cw printer
The print head is probably blocked, run the cleaning cycle multiple times,
There are kits on sale for cleaning the print head but when a new printer costs 60 euro, is it worth it?
Jun 09, 2013 | Office Equipment & Supplies
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
My printer no longer prints black,the colors print ok,but are a little light.Idid everything the maintenance screen told me to doI still can't get the black to print.I used new ink cartridges too.
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
What you want to do to get your printer working again is to clean the ink heads using the maintenance program that came with your printer.
You may clean both the colour and the black ink cartridges. You may need to do this a few times, print a test page between each cleaning cycle. This will get the ink to flow through the printer system. Also leave the printer on for a while so the ink can settle. Ensure that you use original ink cartridges from Kodak as generic cartridges give endless problems.
Make sure they are compatible with your make of printer.
Thanking you kindly
damnor01
Feb 22, 2011 | Kodak ESP 5 Printer
HP Deskjet 950c won't print black
You might be able to use a q-tip with alcohol or acetone to loosen and clean residual ink from the inside and bottom of the black printer cartridge tray--I've even had to use compressed air after loosening the junk after my HP sat for a year. Btw, I'm sure you know this, but the contact pads need to be clean and free of factory tape. I hope this helps.
Feb 22, 2010 | HP DeskJet 950c InkJet Printer
I recently installed new black ink cartridge. Since doing so, the colors on anything printed are incorrect. For instance, anything red prints as pink. Anything deep yellow prints as a gold. MY...
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Color, getting primarly blue in my printed photos
Try cleaning the nozzles of your printer. If it sat unused for awhile, some of the ink may have dried and clogged the nozzles.To clean your inkjet nozzles, open your printer's Properties screen and look for a tab labeled Maintenance, Services, or something similar. If you can't find it, look under Printer Preferences on the General tab. It may take a few times of cycling through the cleaning process to get them unclogged. Check the progress after each cycle by printing a test page.
Jan 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Colors print, but not the black!
that same thing happen to me try to wipe the needle that the ink is on with baby wipes.
Nov 27, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
147 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
