Kenwood How To Connect ts990 to tokyo hy-power HL-1.5KFX amplifier
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I have a kenwood full automatic turntable KD-67F ac 120v 10w 60hz. I dont know how to get the thing to work what else do i need? speekers? or other things if u could let me know it would be a great help
First of all you will need an amplifier, because a turntable has no sound power and its impedance needs to be balanced by a phono input, often found on a receiver or an amplifier. Then you will connect the speakers to the receiver or to the amplifier. I believe that a good start would to buy an old cheap stereo receiver, which has phono inputs, where you connect your kenwood turntable. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Kenwood KD-291RC Turntable
How to connect Kenwood KAC-6104D to a single 4ohm
you want to parallel the terminals on the woofer. a jumper from positive to positive and the same on the negative will equal 2 ohm load at the amp
Feb 07, 2010 | Kenwood Car Audio & Video
I recently purchased a new Kenwood KAC-9104D 1800 amplifier. I hooked it up just as I had with a previous amplifier but it wont power the subwoofers. When one of the RCA cables is plugged in and the other...
You should check and verify first the output signal in the amplifiers by using a multimeter on the db range, this is to identify good output of the amp. After that check the polarities for correct wire orientations.You should connect the speakers one at a time to check.
Jan 16, 2010 | Kenwood KAC-9104D Car Audio Amplifier
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
BLOWN FUSES IN AMP
maybe try the ground or make sure you dont touch metal to metal
Mar 24, 2009 | Kenwood Car Audio & Video
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
37 people viewed this question
 Grubhead
Grubhead
