Question about Melissa And Doug Toy Upright Piano by Melissa & Doug
Piano keys fell out
Need to know the sequence of keys
2 Suggested Answers
momsjustknow
  • 149 Answers
SOURCE: need the order of the keys
Call Melissa & Doug for assistance - From the US and Canada toll-free M-Th 7am - 6pm Eastern or on Friday 7am-5pm Eastern: (800) 718-5365f59424cd58a3851ffefe815890e4a781.jpg?1328824804
Posted on Feb 12, 2012
We bought this upright piano for our daughter to learn on but I can't seem to find any info on it. Serial number 23930. Any info would be fabulous. Thank you.
Remove the front of the piano. Remove the middle C key complete from it mounting pin. You may find the production date and its full service history written in pencil on the side of that key. A piano tuner told me this after I told him that I had removed all the keys to clean them and I was surprised to see the whole history. It said it was standard practice.
Here is some other information.
Concord Mission Style Upright Piano ' The Antique Piano ...
antiquepianoshop.com/product/192/concord-mission-style-upright-piano/ The Concord Piano Company was controlled and manufactured by the famous George P. Bent Piano Company of Chicago, and they built pianos for several ...
Concord ' The Antique Piano Shop
antiquepianoshop.com/online-museum/concord/ (SEE ALSO: CROWN, GEORGE P. BENT) The Concord Piano Company was ... and manufactured by the famous George P. Bent Piano Company of Chicago.
Upright Piano Value ' key-notes
www.key-notes.com/upright-piano-value.html Jun 16, 2014 - Question: I have a Concord upright cabinet grand piano, serial ... Albert's reply: Piano values are based on information such as manufacturer, ...
Piano Manufacturers in Illinois between 1842 and 1908
https://sweeneypiano.com/.../manufacturers/il_piano_manufacturers.cfm The names of Piano Manufacturers and the date year the company was established in the state of Illinois between 1789 and 1911. ... Company, Chicago. Foley & Williams Piano Manfacturing Company, Chicago ... Concord Company, Chicago.
Jan 19, 2016 | Music
How old is my piano?
no way for us to know or find out .
Jan 04, 2016 | Music
Is the serial # printed on the wood inside the piano. That is the only # I see
Finding Serial Numbers on Pianos and Organs
www.omara-meehan.com/help/flash/serial.cfm
The Serial Number -- usually somewhere between four and six. wood or stamped onto the model plate. digits -- is probably located inside the piano on the metal ...
Piano Serial Numbers Search - Find the Age & History of ...
www.total-piano-care.com/piano-serial-numbers.html
Piano serial numbers help to identify the age of your piano and the history surrounding its ... 3) Stamped on the back of the piano; near the top of the wood frame. ... 5)Printed on one the keys - behind the nameboard, inside the piano (newer or ...
Piano Age Request How Old Is my antique piano when made
www.amadeuspianos.com/agerequest2.htm
Jan 01, 2016 | Music
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
How so I fix a stuck piano key
It would depend on why it's sticking. First thing to check is the key bushing felt, then see if the key has swollen and is rubbing the ajascent key. Past that, you'll need a repairman.
My piano won't boot up.
Who manufactures your piano? Call them.
Aug 10, 2017 | Casio Celviano AP-620 88-Key Digital Piano...
Need the order of the keys
Feb 11, 2012 | Melissa And Doug Toy Upright Piano by...
How do you change your chord set-up on an autoharp and is there any reason not to set it up like a piano keyboard (C-D-E-F-G-A-B)? Thanks in advance.
An autoharp makes chords by muting all the strings except those that make the chord. There would be 2 ways to change the chord structure. 1) retune the strings knowing which ones will be muted by each key so that the result is another but valid chord or 2) make your own "keys" so that they mute different strings.
The tuning of an autoharp is selected to allow you to play songs as long as they are in the right key or two. If you set it "like a piano" as you suggest, you could play those chords but not the chord sequences that make up most songs. Most songs revolve around sequences or intervals such as the popular 1 - 4 - 5 blues progressions. Most music has some predictable progressions and that's why the autoharp is tuned the way it is.
You can always experiment with different and odd tunings but if your goal is to play already written songs, I'd stick with the normal tunings - there are alternates.
Jan 29, 2011 | Oscar Schmidt Autoharp
Guitar pick fell in between two keys on Yamaha P-200 piano
If you are willing to try it you can turn it oner onto it's back and find every screw hole and take out all the screws and it will seperate, but you have to be very careful to open it slowly as some components may now be loose, you should ba able to open it up enough to at least let the pic fall out.
Mar 17, 2009 | Music
Melissa And Doug Toy Upright Piano by Melissa & Doug Logo
32 people viewed this question
Top Melissa And Doug Toys Experts
Jennifer Rock
Jennifer Rock
Linda Gentile
Tom Chichester
Are you a Melissa And Doug Toy Expert? Answer questions, earn points and help others
